  • Replies 179
Posted Images
They are great cars for off the showroom floor....i had a boner for it when he first got it. But a ride the other night in my car at 20psi and im feeling the love for my car again. Especially now i have the new gearbox and diff for it :ninja:
Stick with the GTSt, especially since yours looks so trick :ninja:
How can you want to part with that?
You are right! I will learn to drive first......then I will buy and AWD so I can forget everything I learnt ;)
That pic shows where the workshop bent my bonnet :ninja:
Haha - especially if you go the EVO path.
When James was first driving at Wakefield he had very bad brake shudder. Then I went for a spin in his car and discovered you could just hammer up to a corner - and then turn. And the car would go around. Brakes really weren't needed. And neither was talent.
Don't want to get into the my wang is bigger than yours argument, even thou it is!
But one thing to note on the day is that the track temp at EC was very high and the semi's weren't sticking to their full potential. Which was proven when I ran a best time of 1.47.7 on the very hot dry track, then went and ran a 1.47.8 on a damp cooler surface when the rain was a slight drizzle. I wasn't pushing as hard, but the car had the grip back.
Just thought you might find that interesting.
I can't speak for Snowy, but last time I checked - I'm not gay. It's been a while since my last, you know 'check up' though, so ah... nah.
Anyhoo - you guys should stop picking on the way we talk, eh :)
Anyhoo - you guys should stop picking on the way we talk, eh :pirate:
Its ok! We think it is HILAAAAAAARIOUS
Anyhoo - you guys should stop picking on the way we talk, eh :D
Much to my surprise after receiving the Presidents Choice award last year for assuming this Alistair character you so regularly spoke about "may" have been your partner :P
This is great stuff. A lot of passion. The only thing I can add to it is it is a tricky track and to cut some sharp times will take a bit of practice.
The GTRs would have dominated the Zed if we drove them to their limit, but the track got the better of us.
Next time the Zed is gunna have to watch out. I'm putting serious time in on V8 Supercars 3....
Just move to Sydney for a few months. You can work on your tan and dance moves...and if you have time cut some laps at the Creek :P
You guys suck...even though i have done over 15 days at EC, i was only hoping for about a 1:50 flat. So you would have all still kicked my ass. Wakefield is where its at....blood will be drawn at Wakefield in 2007. With Australia Day forever being remembered as the day the GTSt fought back :D
Just move to Sydney for a few months. You can work on your tan and dance moves...and if you have time cut some laps at the Creek :)
You guys suck...even though i have done over 15 days at EC, i was only hoping for about a 1:50 flat. So you would have all still kicked my ass. Wakefield is where its at....blood will be drawn at Wakefield in 2007. With Australia Day forever being remembered as the day the GTSt fought back :)
I am thinking of coming for that one too :)
why do you say that?
Just looking at the tyre sidewall deflection. Looks to me as if it needs about 1-1.5lbs more. Looks like it is going over so far, it is probably hopping sideways a bit if it loses a little grip. Would that be right Jack?
My tyre pressures were up the shit at EC. Couldn't get good grip so took some pressure out, got worse. Put more pressure in and got better. But by then the tyres were shagged. Couldn't do more than 1 lap before it started to understeer like a WRX. A track like EC needs new rubber, will make sure next time!!!!
    • Sounds like it is rotational in the driveline. CV? Tailshaft CB? Also.....didn't you just pay to have that bit painted and put on the car?
    • Yeah, when I dialled my idle down, given how much time I spent idling at the lights in traffic on my daily commute, the effect on overall fuel consumption was absolutely noticeable.
    • Emissions, fuel consumption, heat, noise, etc. most likely.
    • For me at least the reason why it bothers me is because it's indicative of a deeper problem. And that will nag at me forever. Especially because I have tailpipe emissions testing + evap leak testing every 2 years.
    • WELP. I went to the track, and I suppose it went okay because any time you can drive home is okay. You may notice the car is not on the circuit in this picture. It was about 35C day out in Benalla which means the track was approximately the surface of the sun, probably. Good things, car did not overheat but it _was_ warmer than when I had done track days in similar heat before, I think, I'm not sure - I can't quite remember. Coolant got to ~105 via the ECU after 20-30 minutes of belting it in said heat. Oil got up to 145C in one instance which is pretty crazy due to oil cooler. Pressures were fine. I seem to remember this not getting quite so high before the vents. More HMMMM'ing to be done. On the subject of HMMM'ing, can anyone identify the sounds in the video below, you will know which ones I mean: https://www.youtube.com/watch?v=uj3BkI2cbTc I included some 'normal' sound as a reference for the first minute or so. The microphone in this instance was where the license plate is. It stopped working later in the day which is why my "best example of a lap video (not produced)" had internal audio - Isn't hearable from inside the car. I don't mean the chirping of the un-bedded/badly bedded track brakes which you can only hear while braking... Thoughts, brains trust?
