OK, I'm gonna brave the near certain flames I am gonna get for this one, but has anyone out there ever made any enquiries about a dedicated gas conversion to a series 1 RB25DET? I have been asking a few fitters here in WA (wait awhile) and all I am getting is horror stories about melted pistons and such. Now, acording to my research, LPG has a much higher RON than even Premium Unleaded so, in theory, this would be a Good Thing in regards to the tuning scope allowed, not to mention the savings in fuel costs.
The fact that the WA gubberment is now offering $2000 on top of the Federal gubberments $1000 rebate plan means that I will be spending bugger all of my own money to get this done.
My main questions about the conversion are centred around the fact that this would have to be a "blow through" set up and what effects is this likely to have on the standard throttle body? I am seriously considering this because I believe that with a gas dedicated cam grind, a purpose built exhaust and some quality time on the dyno, 200awkw would not be out of the question.
https://www.sau.com.au/forums/topic/142404-gas-conversions/
I think the "Gas Research" gas throttle body in place of std TB would compensate for turbo pressure similar to a rising rate Fuel Press. Reg. does.
Gas Injection like the new Fords have is probably the way to go though, but I dont know if this is available aftermarket or not and wether it would be able to be tuned by aftermarket ECU.
https://www.sau.com.au/forums/topic/142404-gas-conversions/#findComment-2651766
Here’s a quick run down on why LPG is a bad idea;
1. You need 1.3 litres of LPG to go as far as 1 litre of 98 ron.
2. The LPG tank (being a pressure vessel) has thicker walls, hence for the same outside dimensions it will hold 20% less.
3. Add 1 & 2 together and it means 50% less distance between refills compared to he same dimensioned petrol tank.
4. LPG is now 99 ron, the 110 ron dropped to get the price down
5. There isn’t an LPG system designed for RB’s, so you would need one to be made up “special”. Think lots of $’s.
6. They will use a single point gas mixer (not 6 injectors, not sequential), it will simply be connected to the throttle, more throttle opening = more gas squirted in. No fuel mapping as such.
7. Your standard ECU will run the ignition etc
8. Driveability, cold start and run, hot run etc will all suffer as a result of the poor (in comparison) fuel metering.
9. If you live in a cold area you won’t be able to drive your car until it warms up. If you don’t warm it up, drive off and accidentally use too much throttle you may well get a gas explosion in the inlet system. Not large enough to hurt you but large enough to require a top end rebuild.
And a few others I have forgotten.
:wave: cheers :P
I don't think it is a great idea...
https://www.sau.com.au/forums/topic/142404-gas-conversions/#findComment-2651771
    • Nah. For something like boost control I wouldn't start my design with PID. I'd go with something that originates in the fuzzy logic world and use an emergency function or similar concept. PID can and does work, but at its fundamental level it is not suited to quick action. I'd be reasonably sure that the Profecs et al all transitioned to a fuzzy algorithm back in the 90s. Keep in mind also that where and when I have previously talked about using a Profec, I'm usually talking about only doing an open loop system anyway. All this talk of PID and other algorithms only comes into play when you're talking closed loop boost control, and in the context of what the OP needs and wants, we're probably actually in the realm of open loop anyway. Closed loop boost control has always bothered me, because if you sense the process value (ie the boost measurement that you want to control) in the plenum (after the throttle), then boost control to achieve a target is only desirable at WOT. When you are not WOT, you do not want the the boost to be as high as it can be (ie 100% of target). That's why you do not have the throttle at WO. You're attempting to not go as fast as you can. If the process variable is measured upstream of the throttle (ie in an RB26 plenum, or the cold side pipework in others) then yeah, sure, run the boost controller closed loop to hit a target boost there, and then the throttle does what it is supposed to do. Just for utter clarity.... an old Profec B Spec II (or whatever it is called, and I've got one, and I never look at it, so I can't remember!) and similar might have a MAP sensor, and it might show you the actual boost in the plenum (when the MAP sensor is connected to the plenum) but it does not use that value to decide what it is doing to control the boost, except to control the gating effect (where it stops holding the gate closed on the boost ramp). It's not closed loop at all. Once the gate is released, it's just the solenoid flailing away at whatever duty cycle was configured when it was set up. I'm sure that there are many people who do not understand the above points and wonder wtf is going on.
    • This has clearly gone off on quite a tangent but the suggestion was "go standalone because you probably aren't going to stop at just exhaust + a mild tune and manual boost controller", not "buy a standalone purely for a boost controller". If the scope does in fact stop creeping at an EBC then sure, buy an EVC7 or Profec or whatever else people like to run and stop there. And I have yet to see any kind of aftermarket boost control that is more complicated than a PID controller with some accounting for edge cases. Control system theory is an incredibly vast field yet somehow we always end up back at some variant of a PID controller, maybe with some work done to linearize things. I have done quite a lot, but I don't care to indulge in those pissing matches, hence posting primary sources. I deal with people quite frequently that scream and shout about how their opinion matters more because they've shipped more x or y, it doesn't change the reality of the data they're trying to disagree with. Arguing that the source material is wrong is an entirely separate point and while my experience obviously doesn't matter here I've rarely seen factory service manuals be incorrect about something. It's not some random poorly documented internal software tool that is constantly being patched to barely work. It's also not that hard to just read the Japanese and double check translations either. Especially in automotive parts most of it is loanwords anyways.
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
