R33line, $9K damage? must be alot worse than it looks. have you had any luck with the council yet etc?
That was a rough quote, should get the final one in the next few days..
Bent the chasi a little, and from the radiator forward needs to be replaced. (headlights are $500 each)
Most of the quote is labour and they know i'm going through the council so they will drag as much fom the government as possible, not to menchion i asked for a couple of extras including a cf bonnet and the choice of a front bar, and don't forget the front mount........ screw the RTA they can compensate for my loss...
not to mention the mental damage from seing it in a mess
:yes:
  • Replies 57
Posted Images
If all goes well and they agree to pay up, i hope for them to start on the car before xmas so it'll be ready for a cruise i'm to organise with some mates...
Will post it on the site when we come to a conclusion....
so far we are leaving bathurst on the 13th/14th of january to wisemans ferry via bells line amd somewhere from there.... hopes to be a good day, but if anyone knows of a good place to travel from wisemans (eg. the coast) let us know soon cause we will be posting something in the next week or 2 :yes:
Hey guys,
Got the quote after 2 weeks and it is $11,661.
alot more than i expected, but the question i need to know is what is the market value for a 93 model series 1 R33 with 106,000km????.............. just curious cause i still got a large loan on the car.
The Silver R32 GTR from WA in the last post, was the result of horsing around in a fairly powerful GTR coming around a corner in 2WD and Planting ones foot... Had some guys in the car egging him on... Dont think he had it that long
Mike
Hey guys,
Its irelivent as you don't have insurance. If you had insurance and the cost of the repairs are worth more than the car its then considered a write-off. In your case... The car has to be fixed or your in trouble as the car loan requires you to have full comp insurance.
I was told by my insurance company these cars don't have a market value and they need to be inspected individually.
Yer mines started to get a little rust around the back window.
Bastard about it is the ever so small bubble appeared ~6months after it was re-sprayed.
~1000 to fix. :)
i got quoted 500 bucks to fix my rust around back window. bit on either side. and thats including the new rear window seal.
Latest news is the rta has replied and said "YOUR CLAIM FOR DAMAGES IS BEING INVETIGATED AND YOU WILL BE NOTIFIED AS SOON AS POSSIBLE"....... So i'll jog their memory and give them a ring in the next couple of days......... Don't think i'll be lucky enough to get the car back for our cruise to wisemans though kane.. just be goin up with Zeb.
Hi Geoff,
Was good meeting you out at the supersprint at Bathurst.
Man, hope everything gets sorted with this hey.
When I was leaving Bathurst, I had my eye on those trees....watching carefully!
  • 2 months later...
any updates geoff
Gettin the car fixed, but had my solicitor get involved and send them a letter cause they are tryin to get out of it........ hope to have it back on the road by the end of next week..
I'll find out when the next good cruise is and let all the boys know in town and try to join in
  • 2 months later...
    • Is there a way to adjust all of the pedals in an R32 GTS-T? they all sit even, but seem to be a little high for my liking.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
