  • Replies 105
Originally posted by SHUTO-BOY
ask around for WISECO pistons
We just put a set of Wiseco's into a 3sgte.
For the price (about half of the HKS ones) they are great. Wiseco have a good name in the drag racing field and a few places speak highly of them.
Just as a comparaison, they were about half the weight of the standard pistons but will hold upto 700hp !!!
I'm pretty sure they are made in QLD.
J
P.S. - it was cool to see that each piston had a serial no. stamped into them :)
The Japanese tuning shops (HKS, Jun, Toda, Tomei, OS Giken, APexi, Veilside etc) buy their hard engine parts (piston, rods, camshafts, crankshafts, valves, valve springs, bolts etc) from manufacturers like JE, Carillo, ARP, Total Seal, Ross, TRW, Crane, Del West, Iskanderian, Harrop etc They just stick them in their boxes and double the price. There is nothing wrong or inferior about buying stuff from the original manufacturer.
My mechanic has just got a wicked set of forged pistons from the states, i think they are EAGLE but not sure, i will confirm and get a price. These things were super light, and can easily handle in excess of 600hp and they weren't that expensive.
While you got the motor apart you should at least replace the conrod bolts with H/D items, as these are usually the culprit for most blown engines.
Originally posted by INASNT
will they be about $1500 for a set of 6?
Got a price for you.
The 4 he got for the 3sgte were $1086, and that included all new rings and some sort of special pins as well.
They were the stock size (not oversized).
I hope that helps
J
Guest INASNT
I hope that helps
J
so for 6 it will be about $1500 odd then.
if u put oversized in u gotta change sumthing else 2 dont ya? shortened rods?
Put in some nismo big end bearings, and some arp bolts while your in there...and if you really wanna load on the power, get the block o-ring as well....hell, even do the conrods while your in there....
Pistons might not be the first thing to go flying while ya turn up the boost mate... if ya wanna account for one thing, be prepared for something else to happen
Son of Sydneykid
Guest INASNT
Son of Sydneykid
yes i could go fully sick and put in HT valve spring, bigger valve, race ported head etc etc etc, but i aint building a race engine, just something that can handle 250rwkw or so and not shit itself when i give it some stick
Guest Sir Bean
what turbo and what boost are you going to run to make this power?
Whatsisname is making 257rwkw on an untouched engine. He makes it on only 13psi though.
The JMS 33 drift car makes 300ish rwkw on a std engine at 1.5bar or so?
If you have a good condition, low km engine it probably wont be necessary to open up the motor, and as you say, your not building a race engine. But with that said, there is nothing like peace of mind!!
Id be very interested in what it costs you if you go ahead! (I like peace of mind)
Like sydneyking said, you upgrade the pistons and something else that you left standard will go bung .. So i'd be doing a stack of things at the same time while the engine is apart but its going to cost you heaps then.
Personally, I'd just putting your bigger turbo and seeing what happened. If the pistons crack or something else goes, then you spend all the money getting whatever replaced. Call it a live "stress" test for your engine :P
Special Piston Services in Melbourne (03) 9793 1110
They made the forgies for my Capri turbo engine using a
Ross blank! They makes slugs for AVO i know!
Have heard they use Arias or Ross blanks & then machine them to suit engine!
They can organise HPC coating of the pistons as well!
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
