  • Replies 105
Originally posted by SHUTO-BOY
ask around for WISECO pistons
We just put a set of Wiseco's into a 3sgte.
For the price (about half of the HKS ones) they are great. Wiseco have a good name in the drag racing field and a few places speak highly of them.
Just as a comparaison, they were about half the weight of the standard pistons but will hold upto 700hp !!!
I'm pretty sure they are made in QLD.
J
P.S. - it was cool to see that each piston had a serial no. stamped into them :)
The Japanese tuning shops (HKS, Jun, Toda, Tomei, OS Giken, APexi, Veilside etc) buy their hard engine parts (piston, rods, camshafts, crankshafts, valves, valve springs, bolts etc) from manufacturers like JE, Carillo, ARP, Total Seal, Ross, TRW, Crane, Del West, Iskanderian, Harrop etc They just stick them in their boxes and double the price. There is nothing wrong or inferior about buying stuff from the original manufacturer.
My mechanic has just got a wicked set of forged pistons from the states, i think they are EAGLE but not sure, i will confirm and get a price. These things were super light, and can easily handle in excess of 600hp and they weren't that expensive.
While you got the motor apart you should at least replace the conrod bolts with H/D items, as these are usually the culprit for most blown engines.
Originally posted by INASNT
will they be about $1500 for a set of 6?
Got a price for you.
The 4 he got for the 3sgte were $1086, and that included all new rings and some sort of special pins as well.
They were the stock size (not oversized).
I hope that helps
J
Guest INASNT
I hope that helps
J
so for 6 it will be about $1500 odd then.
if u put oversized in u gotta change sumthing else 2 dont ya? shortened rods?
Put in some nismo big end bearings, and some arp bolts while your in there...and if you really wanna load on the power, get the block o-ring as well....hell, even do the conrods while your in there....
Pistons might not be the first thing to go flying while ya turn up the boost mate... if ya wanna account for one thing, be prepared for something else to happen
Son of Sydneykid
Guest INASNT
Son of Sydneykid
yes i could go fully sick and put in HT valve spring, bigger valve, race ported head etc etc etc, but i aint building a race engine, just something that can handle 250rwkw or so and not shit itself when i give it some stick
Guest Sir Bean
what turbo and what boost are you going to run to make this power?
Whatsisname is making 257rwkw on an untouched engine. He makes it on only 13psi though.
The JMS 33 drift car makes 300ish rwkw on a std engine at 1.5bar or so?
If you have a good condition, low km engine it probably wont be necessary to open up the motor, and as you say, your not building a race engine. But with that said, there is nothing like peace of mind!!
Id be very interested in what it costs you if you go ahead! (I like peace of mind)
Like sydneyking said, you upgrade the pistons and something else that you left standard will go bung .. So i'd be doing a stack of things at the same time while the engine is apart but its going to cost you heaps then.
Personally, I'd just putting your bigger turbo and seeing what happened. If the pistons crack or something else goes, then you spend all the money getting whatever replaced. Call it a live "stress" test for your engine :P
Special Piston Services in Melbourne (03) 9793 1110
They made the forgies for my Capri turbo engine using a
Ross blank! They makes slugs for AVO i know!
Have heard they use Arias or Ross blanks & then machine them to suit engine!
They can organise HPC coating of the pistons as well!
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
