on a start up there is a weird knock in my motor when its warm it goes away.its kinda a yuk and scary noise..i will start my car in the morning and get this weird knock rattle noise at idle which is scary..anyone have the same noise and what it is..my car has only 80klms on the clock..any ideas cheers fellas
https://www.sau.com.au/forums/topic/142453-weird-knocknot-sure/
Most likely you are describing lifter noise.
Read this: http://en.wikipedia.org/wiki/Hydraulic_lifters
"Frequently, the valvetrain rattles loudly on startup due to oil draining from the lifters when the vehicle is parked. This is not considered significant provided the noise disappears within a couple of minutes, although typically it usually only lasts a second or two"
Normally I would be wary of what is on wikipedia, but this information looks to be fairly correct.
Try using a thinner oil, that should help the noise to go away faster.
i doubt it will be lifters if the noise sounds so bad that it concerns you. as for lifters my mate wacked some additives made for sticky lifters which has reduced the ticking noise dramatically.
oh yeah my other mate and his wrx had something similar. loud as ffff rattle turned out to be one of his timing belt pulleys shearing/wobbling itself off. luckily we picked it up in time before it completely fell off. have a look =)
Edited by (B1) MR_fanny
Lifters (or hydraulic lash-adjusters as they are more correctly known on, non-RB26, DOHC powered 'Lines) don't 'knock', the sound they make is more of a sharp 'ticking' noise if they are low on oil pressure (thats your valves hitting the seats more harshly).
A dull knocking is likely to be more serious. Just get a mechanic to have a listen with a diagnostic stethescope.
can the rockers be adjusted on a rb25 at all as my sons car has some lifter noise if not any idea on how much a set of lifters is worth ?
cheers
RB20/25/26's don't have rockers (unlike SR20/RB30/L-series engines), the cam lobe acts directly on the lash-adjuster, which controls the valve opening/closing.
Engine oil flush may clean up the supply galleries and make them run quieter, but if your son is prone to thrashing the car, they will often sound tappety as they "pump up" with high oil pressure and increase the valve clearances.
Become a member of the club and give Lincorp spares a call if you want to purchase new ones.
Cheers :(
yeah its a bit weird.it deffanatly has some thing to do with oil i hink..when i rev it off idle the noise goes straight away which im guessing cause if the oil pressure build up.its deffenatly a knock not a tick if you no the diffrence between the noises..its deffanatly not normal and never use to happen..ill try a good flush and maybe get a good mechanics view on it..any one recomnd any places around the parramatta area..cheers guys
  • 9 months later...
What was the result of this?
Cheers
Dazzzler
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
