Greetings once again,
Today I have for sale my Light-weight rims. They are made in the UK and their website http://www.speedlinecorse.co.uk/ states that:
"Speedline is the only wheel manufacturer in the world that is able to produce magnesium wheels to road going standards. These are the ultimate in premium wheels. Lightweight, high strength and exclusive."
From my knowledge they usual go on exotic European cars such as Porsche.
One of the main reasons why I am selling is because the offset does not come out far enough to suit my GTR. I am most confident that they will suit a GTST (R32,R33 and R34) and give a more solid look to your car. I have enjoyed them in the time I have used them, but I think its time to get the right offset.
They are 17 inch by 9 inch wide. No repairs have been made, so you can be sure they will balance OK. Im not sure of the offset value, but they just dont fit the GTR nicely.
I am selling these rims with the tyres, that are 245/45 R17 on all four. The rears have 1 week old tyres and the fronts have about 30% left on them.
These rims are not brand spanking new so they do have gutter marks on them but they arent bad at all.
post-16885-1162977744.jpgpost-16885-1162977757.jpgpost-16885-1162977768.jpgpost-16885-1162977785.jpgpost-16885-1162977799.jpgpost-8436-1128484236.jpgpost-16885-1162977831.jpg
Pricing:
I will sell these at a Max of $1100 but I am open to reasonable offers.
I can post interstate but of course it will be at your cost.
You can pick up if you live around Brisbane
Consider this as a bargin for you
Thanks!! Good luck
PM me, Email me, Ring me. I wont reply to SMS
[email protected]
0402 565 791
Brisbane!
Edited by arbess
    • That's a good point. The rears of the covers themselves have no baffling at all though. Higher up more chance of air for venting the crank case. Lower on the side more likely to be submerged. I might be able to fit them on the sides but with both the sump drain fittings being on the drivers side the passenger one will need to make a U Turn and be nearer the turbo. But it will look neat being not up on top.
    • It won't likely matter where along the cam covers you put the big fittings. I would suggest putting them on the sides if you can, simply because it will reduce the flow up through the baffles and thus reduce the amount of oil that gets put into the foam. It might not matter, but it seems like something to consider as a worthwhile thing to avoid.
    • Well, I have my IM240 results with a cammed LS1... My Nox was 0.11 and my CO g/km was 0.2. Euro4 is 0.08 and 0.1 respectively. I'm gonna say for a stock RB this is actually plausible, BUT in Australia they were complied pre-Euro2, so the limits were: Which as you can see, is way higher. I'd say a stock RB with a new OEM Cat could? actually pass Euro4 for NOX but you'd probably have to do a hell of a lot of testing to prove it, and getting a car emissions tested and carrying a certificate of emissions when/if you get pulled over may be cost prohibitive if it's even allowable to get your car tested and re-classified. You'd have to find out what the UK Govt is using as reference material. It may be non-negotiable.
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
