1993 BNR32 SKYLINE GT-R
SOLD
Personally Imported in 2003.
Travelled 119,000ks (Original Klm)
3,000Klm Since Rebuild
Full service History Book + All Receipts
12 Months Rego
ENGINE & SPECIFICATIONS
RB26DETT
Full Rebuild Engine
Block, machined, bore, hone, decked, tap oil galleries,
balanced/blueprinted
Arais Forged Pistons
Eagle Conrods + Bearings
N1 Crank
N1 Oil Pump
New Water Pump
Genuine Head Gasket Kit
Platnum Spark Plugs x 6
INTAKE & EXHAUST
Standard GTR Intercooler
Twin K & N Air Filters
HKS Type x2 Front pipes
Custom Cat
Kakimoto 3" Full Twin Stainless Steel Exhaust System
TURBOS, ECU & FUEL
Standard Rebuild Turbos + High Flow, Steel Wheel
HKS Type Stainless Steel Dump Pipes
HKS Type Stainless Steel Manifold
Apexi Power FC Computer
Sard 700cc injectors
Bosch 044 Fuel pump
Blitz II Spec R Boost controller
DRIVETRAIN
Extreme Heavy Duty Clutch
Custom Surfaced Exhaust Manifold
Custom Surfaced Flywheel
SUSP & BRAKES
Tein HA Adjustable Coilovers
Standard R32 GTR Pads
WHEELS & TYRES
R34 GTR Wheels 18 x 9.0 Bronze
Pirelli 265/35/18s
BODY & INTERIOR
Genuine Xenon Headlights
Sony Headunit with 6 stacker + Remote control
Cyclops 2 Point Immoboliser Alarm System
Tinted Windows
Immaculate Standard Condition Interior
POWER
300rwkw @ ProTek Automotive pump fuel on 19psi (Dyno Sheet + Video)
All work done on this vehicle was performed by Dom @ ProTek Automotive in Reservoir, Car has never been raced or track used, Has been 3,000klm Since Rebuild, and had its 1st Tune on Wednesday 9/11/2006
Alot of $$$$ Spent on the Vehicle, comes with Receipts
For More Info Please Call
Rama 0403-312-736
Vehicle is Located In Melbourne, Can Organise Interstate Shipping
SOLD
Edited by sssrama
https://www.sau.com.au/forums/topic/142508-1993-skyline-gtr-r32300rwk/
    • But it's much better to use a freedom unit that has four different possible meanings...
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
