Hey pplz,
I was wondering if anyone knows how much some remapping of the standard R32 gtst computer and who does it. I was also wondering if u could get say a chip that would take the speed limiter off ,and crank up the fuel a bit.
If anyone knows who makes these kind of mods and for how much I would really like to know.
Thanks allot guys.
https://www.sau.com.au/forums/topic/14251-r32-computer-mods/
Dr Drift from melbourne has been chipping r32 ecu's. I think its just an addon chip that goes inside. I know he does it for a good price, but cos hes in melb, dont know what can be done. It might be worth sending him a PM just for some info on what he uses and how its done.
My r33 ecu has been chipped to remove the speed limiter, so it can be done. I also have an unused tomei limitter over system (speed limit removal) for sale which will do the same thing.
https://www.sau.com.au/forums/topic/14251-r32-computer-mods/#findComment-287450
burt, i'm pretty sure the r33 computer can't be chipped. u would have to go aftermarket computer, an apexi power fc plugs straight onto the standard wireing loom and can be tuned by gavin woods on the gold coast.
if u can't afford that i think u can get a microtech for less than $1000, these r a map sensor based ecu so u can get rid of the AFM. there a bit of a pain to hook up though, u need to find the wires from all the sensors and connect them to the microtech, the main advantage is there australian made so plenty of ppl know how to tune em.
https://www.sau.com.au/forums/topic/14251-r32-computer-mods/#findComment-312277
Guest 382 GZV - 4 Door R33
What the heck - why not just go for broke and get a HKS f-con V pro, and while your at it get the JUN vice-president over to tune it - he'll do it properly I've read, bit on a dyno, then on the drag strip and road.
Don't know how much it would cost though, probably more than my car!
https://www.sau.com.au/forums/topic/14251-r32-computer-mods/#findComment-316390
  • 4 weeks later...
I have an f-con V non-pro but i cannot get anyone in queensland to install/tune it SHIT! haha. Im lookin into tuning roms myself removing the speed limit and increasing rev limit are very easy. I just need someone with the skill to teach me 3d fuel maps. i have a mate with a dyno dynamics dyno and ive got the computer skills so will be up and running soon.
https://www.sau.com.au/forums/topic/14251-r32-computer-mods/#findComment-356263
  • 3 months later...
the chiptorque chip is a special board that fits into an EPROM socket which can be flashed programmed by chiptorque only. its got copyprotection on it so it can't be ready by a conventional EPROM programmer. that is what you pay $500 ... their piece of mind cos you really pay for the tuning afterwards
not that its impossible to read the flash chip by other means :-)
https://www.sau.com.au/forums/topic/14251-r32-computer-mods/#findComment-551447
i will be selling my mines ecu out of my r32 skyline very soon probably, it has better fuel and ignition maps and also has the speed cut removed no boost cut and raised/removed rev cut also.... on my mildish r32 this seemed to improve power and torque substantially..... just an idea anyway...
https://www.sau.com.au/forums/topic/14251-r32-computer-mods/#findComment-552604
    • We have some genuine Japanese legally decommissioned car number plates now in stock 🙂 Add some legitimately obtained JDM style to your Skyline or other Japanese model, or simply as a garage/man cave decoration! About the 40mm hole: The Ministry of Land, Infrastructure & Transport in Japan recognised the popularity of keeping decommissioned plates among car enthusiasts and came up with a method to "destroy" (or render them unusable for street use) while still retaining their collectable/usable value for display etc.  We have 40mm hole covers available to cover the hole nicely with a Sakura motif, which are also available in white in (very!) limited quantities, however they frequently sell out. Please let me know if you're wanting one or more of these and I'll check availability. The Sakura motif covers are more common. https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-su-7515 https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set https://www.oemsoko.co.jp/products/genuine-japanese-vehicle-number-plate-400mm-hole-cover *Please note that we can't obtain particular number or area name (eg: "Gunma 500 Fu ・86") if requested. All plates are provided as they become available after decommissioning.
    • Ah, fair enough. For the IAT, I'm using a legit GM sensor that was used on the car prior to my current build. I'll get another wideband and IAT ordered and follow up when they show up. Thanks for the help.
    • You shouldn't need to massively fatten up the mixtures for cold conditions. For one thing - 0°C is not that cold. For another, the Haltech will be using the IAT sensor to tell it how dense the air air, and calculate the correct amount of fuelling. Then the cold start enrichment is added as a % on top of that, so it should scale with the main fuelling. You might also doubt the IAT sensor at this time. You're not using one from an RB26 are you? Using a nice Bosch sensor or similar? Happens. Some wideband units take great pleasure in killing their sensors. Put another wideband in the tailpipe and compare. Or just swap the sensor to a brand new one and see.
    • Oh, my misunderstand. When the car was running, it sounded ok, but if I gave it any gas it wanted to die but caught itself afterwards. It's very different from how it was a couple months ago when it was warmer outside. The logs show that the AFRs are better during, what I assume, is warmup enrichment. Because it's cold, and air is more dense, should I work on the enrichment bit?
    • yess of course im not using 2nd hand parts from my spare engine, but the place where i live is hard to find parts for the RB20DET ,but for the RB20E is everywhere including new ones and a lot cheaper ,because for the RB20DET you have to order it overseas to get one and it cost a lot of money 3x the price to be exact. so i ask this topic because if i can use the new ones but for RB20E is it compatible or not. if not im screwed haha, not totally screwed but i have to save a lot of money first before i can begin repairing my engine, thanks for the information before.
