R33 Gtst Smic Upgrade To R34 Smic - Results (video & Pics)
QRI05E
 Share
Hi there ...
I see, your grill is not exactly SMIC friendly :down:
No wonder you switched over to the FMIC.
If it wasn't for the good price I would have gone for the FMIC myself but I want to gain experience with the car step by step.
So the R34 SMIC seemed like something reasonable to start from. Cheap, easy to fit and modest gains (?)
(especially with the standard turbo)
My car is 99% stock and right now I'm just aiming at stage I tuning.
As for the R32 actuator I agree, however these are hard to find (I keep looking though)
Cheers and good nite ;)
Edited by Torques
  • Replies 68
Posted Images
  • 2 months later...
No, you will not mate the R33 and R34 turbos are much the same except for a slightly larger exhaust housing on the R34. So unless you upgrading your turbo keep the stock GTT cooler. Its a good unit and you wont loose any throttle response to that of a large frontmount.
always good to see these cheep mods work.
cheers
I would like to do this mod. Are there other things i need for the upgrade (eg hosing & pipes of a different size) or can i use the existing ones on my stock r33?
Hi!
.. it's a straight plug in replacement (at least with my R33S2) ...
Everything fits except that the unit is a bit thicker/deeper so you might have to adjust the plastic mud guard a bit.
R34vsR33Smic
i have installed 34 cooler on my ceffy and on my 33 much happier than any front mount i have ever run all thou my power has never exceeded 220, had front mounts fitted on my 180 and both 32's made them feel so much heavier obviously lag but not a good feeling. !
big ups to 34smic =)
  • 1 year later...
I have a 3" catback with K&N pod stock everything and did this mod this morning. Fitted in about 20 minutes tops. I had no plastic guard on the front of the cooler.
Im sure its just me, but the boost comes on alot smoother and I think maybe higher in the RPM range now. I guess things are going to lag a tiny bit more compared to a smaller intercooler and this is more of a mod to cool the air down rather than to boost HP.
Once I go do the boost solenoid mod in a minute im sure the power will change a bit. Next mods are boost gauge, RB20 10psi actuator, split aftermarket dump, hi-flow cat, CAI and SAFCII. Then that will have to do me as I want the R33 as a daily... and my EB Fairmont is the car I want to make go really fast for weekends/wednesdays =)
Wow what a difference $40 worth of intercooler and 5 minutes worth of boost solenoid modification makes... just took it for a spin around the block. I think higher psi lower in the rev range is better because I don't like revving the crap out of the engine, but I want the boost down low. I think I'm going to try set the skyline up for responsiveness and mid-rpm power.
 Share
    • Hi fellow SAU members, I want to put coupe tail lights on my R32 sedan. I have been told it was as easy as changing the boot lid and the tail lights and possibly the rear bar. I have since found out that this is incorrect after buying the lights and boot. The coupe boot dosnt allow the boot to oprn on a sedan and the tail lights won't fit either. Has anyone done this or seen it done and could help me out with some guidance or instructions to get it done.
    • Noice one 👍 I've done a 1:16.300 at Watkins Glen, will keep at it. Still have to knock off half a second at Suzuka in the Roadster
    • Two golds! Struggled to get silver on Gran Valley.
    • Interesting that it has 2 to the USB stick. Are the ones to the USB stick different? Or labelled anything at all? Telstra 4G is Band 28 is the long range one you want, it's 700mHz. I'm trying to do some reading on the Cel-Fi stuff, but I can't find any decent info online that makes me feel comfortable being able to work out the sort of antennas we could get away to swapping it over to. The antennas I'm starting to do some stuff with at work, are a transparent antenna. They're designed to stick onto the window. Which means you wouldn't even have the antenna outside the car. Volkswagen have just started using the exact same types of antennas on some of their new cars (And from the same antenna manufacturer). But, RF stuff is a bit of a dark art some days, and getting it wrong in your car could make for a terrible waste of money trying to swap antennas :S
    • I'm not going to lie Duncan, Saturday and Sunday were pretty rough days. The sort of work I was doing would previously have ended up with me spending about an hour and a half chatting with Neil. Firstly about something I had a question about, and then both of us rambling off on tangents.  I think how Neil did things, and his attitude to getting it done is helping me in part to get this stuff done. Then I can actually do the things I enjoy more easily
