Hi guys,
I have a fully rebuilt RB26 in an R32 GT-R. GT-SS turbos, HKS everything else (manifolds, pipes, pistons, rods) + Tomei poncams.
As you've guessed from the above, the car is built for response.
I took it out on track yesterday (Wakefield) and damn it's laggy. Boost starts kicking in at 4500rpm. Is this normal? I also drive an EVO 6.5 dead stock and that kicks the boost in at 3000rpm. I know I shouldn't be comparing the GT-R to the EVO. But I just wanted to know whether or not full boost at 4500rpm is normal?!
Maybe it's more about the car being so slow off boost. It's ridiculous, slower than a Barina off boost!!! Any suggestions, feedback, opinions, all appreciated. Thanks.
UPDATE UPDATE UPDATE 29/NOV.
It was the boost controller! Wasn't set up right. Wheeeee!!! Much more response, a whole lot smoother on boost too. Now to take it to the track again! Shame it's so damn hot at the moment.
Edited by justinfox
  • Replies 119
Funny! GTSS turbs were what I was going to get due to responsiveness.
It could be: Tuning what sort of mapping was done in the spool up low revs area.
Restriction in exhaust?
Maybe if you had GTRS turbs you would have this issuse but you don't and thats crazy it's so laggy!
Anyway good luck on your problem.
Hi guys,
Something is definately wrong there Justin.
I have GT-SS's on my car and they are probably the most responsive turbos you could pick for your RB26
I will check my dyno sheets later tonight and get back to you with some more info if you like.
yeah im a bit curious about this too
cause i am planning on getting GT-SS's for my gtr and if thats the lag i dont want them
RellikZephyr
Easy tiger, dont go changing your plans because of this - there is something else going on thats causing Justins turbo lag
Your car seems to be a ball ache. First the 2530s were laggy, now the GTSS. Have you been for a ride in other cars with similar setups. You should have gone for a ride in the white R33 GTR at Wakefield, basically a std motor with turbos bigger then yours.
If its worse then your car then there is a problem with your car. If its about the same then you have to come to terms that you are running twin turbos, which can provide almost 600hp of airflow, but with only 2.6L... it is a turbo car.
Your EVO runs a small little turbo with boost up the brazoo...so will always be responsive, will especially feel that way because of the gearing, weight and turbo of the car
GT-SS should be on the juice virtually like a standard turbo, and just have a LOT more top end compared to the stock turbos.
There is something wrong with
1) Boost Control
2) Tune
3) Cam setup
4) Exhaust restriction
Thats some stuff go get started with, but for anyone else thats reading this, this is NOT normal for GT-SS turbos.
So dont be put off by them, this setup just has issues :whistling:
I am pretty sure it's the tune. Here's my dyno sheet.
I have a similar problem with my r34n1's and my mechanic reckons its the tune cuz my exhaust cannot be blocked (or so i assume as I have a new cat as well as front pipes) So im going to get mine road tuned in a couple of weeks to see if they can find the problem. Good luck with yours!
That's all I got dyno sheet wise. It's on 1.2bar.
Exhaust is fine (HKS manifolds, piping kit, front/dump, high flow cat + Kakimoto Regu96 all the way back).
Boost is controlled via AVCR. I would love to get someone else to tune it but that will definitely void my warranty on the engine as currentlky the builder is the tuner. Looks like I'm in a situation then huh?
Do you know the boost settings and gain settings on the AVCR?
What type of computer do you have?
Hmm interesting i may have to check my boost controller see if they set the gain really low!
Justin, I dont know of anyone who has ever tried to claim on a warranty for an engine rebuild!
Take the car to CRD and get Jim to sort it out or at least check the tune without adjusting it so your warranty is safe but you will hopefully then know exactly whats going on/holding you back.
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
    • Hmm. I've gotten pretty good outcomes from talking to them about things that I've had go wrong or ideas for improvement. Have had a lot to say about the R32 FUCAs, and they have sent out some replacement parts for those, gratis, on a couple of occasions. Mind you, I have bought a couple hundreds of $ of replacement rod ends for them too!
    • I have a r34 sedan 1999 manual converted need some help with my speedometer it only reads upto 98km and then stops currently still running the auto cluster any easy fixes no speedo drive is connected yet, if someone has a video for wiring up the manual speedo sensor with the auto cluster please send through
