Just an UPDATE everyone.
It was the boost controller! Wasn't set up right. Wheeeee!!! Much more response, a whole lot smoother on boost too. Now to take it to the track again! Shame it's so damn hot at the moment.
Good stuff mate....great to hear its all sorted. Those AVC-R's are a tricky unit for some to set up....from memory a car i set-up at the SAU dyno day a while back, went from 255 to 289 kw just from a bit of a tweak on the duty cycle during a few spirited laps of Victoria rd.
Blitz dual solinoid controllers FTW!
  • Replies 119
Maybe standard R34 GTR turbos ... there's another idea about your car I had the other day...
yeah that's a good point. the engine was built in 2002 so they would have been cheap and plentiful in japan then. it would make sense as it's very responsive, but not overly powerful. I'd be curious to see what happens at 18 or 19psi, but not game to test it out until I know for sure what they are.
It's pretty easy to pick the r34 turbos the comp housing has a A/R 0.53 marked clearly on it and should be visible even when installed.
pete
I have R34 GTR turbos in my 32 (at least thats what I was told when I bought it), but I nver knew how to tell. So its easy to see the A/R 0.53 by looking at them with the filters and piping on the car?
Whats written on std 32 turbos?
well when i mean easy i mean you won't have to strip the car to but a small mirror might make it alot easier and the r32/r33 will have .42 a/r marking on the comp housing the r34 is the only turbo i know of with the .53 comp housing and it is mark as such. As i got to broken ones in the shed at home off clients car.
pete
ps dont boost to 18psi as even the r34 break wheels and destroy motors (damn ceramic wheels pain in the neck)
Edited by pnblight
yeah, lol. it comes on fast and early and stays there. profec B II and HKS wastegate actuators to thank for that i guess. I think it's quite a good graph. it's taken me a while to get there. very meaty, and lots of area under the curve. all through optimising stock gear. the only question mark is turbos as I'm not 100% sure they are stock, but power output would suggest they are, or maybe 32N1s.
wont be 32N1's as they are shockers, less response out of them than GT-SS, you'd know about it if you had them as you wouldnt be as happy as you are.
They would come on late and not make much more power... more similar to Justins first post kinda thing if you did have 32N1's.
thanks for the tip pete. I will check again. but I dont think mine have the AR marked on the outside. the 34N1s I've had before (and most stockies too I think) had the comp AR stamped just inside the compressor outlet :)
you could be right about the lag thing ash. one thing it's certainly not is laggy. has a massive area under the curve, boost comes on early it makes lots of torque
good man! I want to see your thing hauling arse. :) at least you know there is heaps to be gained with your set-up. you have all the nice gear I dream about, but I guess with any new set-up it just needs some optimising. mine took a lot of tweaking to get the curve looking way it does. yours will look the same when finished, only with much bigger kw number at the top :)
Because I'm bored I did a little comparison of the old average power. it's not exact, but close.
the three collumns are speed, my power, your power
80 85 60
100 155 70
120 190 120
140 225 190
160 245 245
180 260 268
me: 1160 / 6 = 193.3 average
you: 953 / 6 = 158.8 average
doing these rough average power calculations will give a good idea of how it fast it will be on the road and track.
that one is kind of flawed obviously because yours was having the EBC problem which I'd guess was killing resposne and hence average power was way down on where it's at now. once it's tuned post up the graph and we can compare again. it will help me to decide if I should move to the SS too. :) i'm picking your average power from 80 to 180 will be well over 200kw atw.
This thread is very helpful! I think I have found the problem to my lag issue and going to get it retuned this weekend at CRD. I believe its my boost controller's START BOOST setting being set at 0 which means my wastegate is always open?? I have a greddy profec b spec2. I know Beer baron you have one of these maybe you can shed some light on what you have urs set at? :) I believe this is a very simple to use boost controller and sometimes still confuses people, even the reputable guys at UAS! I'm glad i decided to read the manual :D
Edited by PhilGTR
Duty setting? For the life of me i cant see how ppl get it SO wrong as to affect the response of the motor like experienced here. Im not saying anyone is right or wrong, just pointing out that its very surprising that its the settting of the EBC. Without even knowing what i was doing i got my AVCR almost spot on. After reading the manual i was able to get it spot on...and have since helped a few friends out with getting theirs to work top notch. They were all singles though so that could be the reason????
Interesting >_<
Ahh nice to hear justin good to see its sorted now!
i've been away for a month, havnt been down to brads for a month or so.
i was with beau the other night when he was painting his front bar and i took off my exhaust and took it for a drive with just front pipe on. and it made a hell of a difference to my problems i am having! which i beleive is mostly boost controler related also.
also a f**ked muffler is contributing to my car bieng a slug..
This thread is very helpful! I think I have found the problem to my lag issue and going to get it retuned this weekend at CRD. I believe its my boost controller's START BOOST setting being set at 0 which means my wastegate is always open?? I have a greddy profec b spec2. I know Beer baron you have one of these maybe you can shed some light on what you have urs set at? :) I believe this is a very simple to use boost controller and sometimes still confuses people, even the reputable guys at UAS! I'm glad i decided to read the manual :)
Hi Phil. yep, your start boost needs to be much higher than that. it basically controlls how long the wastegate stays shut. so if you are after 1 bar I'd suggest a start boost around 0.8 bar or so should be the ticket. set warning to 1.2 bar, with boost reduction to 20% if warning is exceeded for more than 1 sec. gain and duty I cant remeber of the top of my head. but if you looks back to the last page you can see how fast it ramps onto boost, and how stable it stays once it's there. that was about 10 or 20 mins spent tuning the Profec B II. :P
can't wait to hear how things go for you today Justin. Where is it being tuned?
Thanks beer baron! i have it on 10psi at the moment and it feels much much better. ;)
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
    • Hmm. I've gotten pretty good outcomes from talking to them about things that I've had go wrong or ideas for improvement. Have had a lot to say about the R32 FUCAs, and they have sent out some replacement parts for those, gratis, on a couple of occasions. Mind you, I have bought a couple hundreds of $ of replacement rod ends for them too!
