upgrade to a Z32 afm and get a tune to suit, it will be better in the long run as the rb20/25 afms are somewhat restrictive.
I have found Croydn Racing Developments (site sponsor) to be the best priced supplier for the Z32 AFM
hope that helps!
https://www.sau.com.au/forums/topic/142541-afm-question/#findComment-2654235
hope that helps!
What he said
RellikZephyr
https://www.sau.com.au/forums/topic/142541-afm-question/#findComment-2654337
hey,
since these things go all the time on skylines i was wondering where the chepest place around BRIS to get these and is it worth getting on from the wreckers?
cheers
I have one for sale - $150 including postage to bris
https://www.sau.com.au/forums/topic/142541-afm-question/#findComment-2654342
thats a bit better than $$250 second hand that i just got quoted!, the hide of some people. so r32 and r33 afms are interchangable/the same? i got a mate with a 33 so if its the problem ill pm you 2rismo
https://www.sau.com.au/forums/topic/142541-afm-question/#findComment-2654571
He wants to replace the standard one Eddie :happy:
the cost of a new Z32 AFM is about $450 including plug might no be worth it dont forget the tuning/remaping price....
but from what i was informed the 32 is interchangeable 33.... dont quote me though....
but still 150 for AFM delivered is not bad....
https://www.sau.com.au/forums/topic/142541-afm-question/#findComment-2654898
is the Z32 AFM, fully compatible with the PowerFC?
do any of u have or use this setup?
yes, was looking into this option (have the Power FC already) but its not really worth it unless you want huge horse power or have 500+ dollars just lying around.......
https://www.sau.com.au/forums/topic/142541-afm-question/#findComment-2657605
I dont personally but am going to if funds permit.
The power-fc has a setting for the z32 and the q45 I think, please someone confirm?
https://www.sau.com.au/forums/topic/142541-afm-question/#findComment-2658367
about 200kw (depending on what mods of course) is where the standard afm runs out of resolution
https://www.sau.com.au/forums/topic/142541-afm-question/#findComment-2658392
Only series 1 AFM's are interchangeable with R32 RB20DET AFM's. The Series 2 has a 3 wire AFM with a pink label.
Don't forget that you can't just wire in a Z32 AFM and away you go. The ECU will have to be remapped...which is not possible on the R33 ECU. This means you will need to buy an aftermarket ECU like a PFC of something similar. You have to ask yourself what you want out of the car. Over 200rwkw? Then upgrade it.....if not then leave it.
https://www.sau.com.au/forums/topic/142541-afm-question/#findComment-2660558
https://www.sau.com.au/forums/topic/142541-afm-question/#findComment-2660561
    • I removed the head expecting to find broken and bent valves, but instead found number 1 at TDC and cylinder 2 at the top of its cylinder stroke as well, thought that was weird and proceeded to push cylinder 2 back down until it either bottomed out on its other piston half or the conrod either way we found the issue kind of,  now to remove the engine and see how the block looks, hopefully its just the top off a piston.
    • A little more work this week.  Fitted astra power steering pump in the boot with a lowe fabrication bracket. Gave the pump a good clean, fitted Anderson plug and high pressure fitting. With the intercooler being flipped under rad support factory headlights weren't going to work. Ordered a set of origin battle lights, they arrived so got them test fitted. Will require some fiddling to fit nice but was an easy quick option for now. And today we pulled out the manual Rb gearbox and test fitted a ZF 8HP50. It will fit with some casting tabs cut off and small tap of the tunnel with a hammer. Pick up the adapter plate Wednesday so hopefully all bolted in Friday and measure for tailshaft which will be a 2 piece. Been doing a lot of ecu, pdm and tcu loom design so when comes to wiring it in a few weeks will all go smoothly.
    • FYP. Sadly. Even bolt cutters wouldn't take 2 sec. But in the days of 18v angle grinders, nothing is safe.
    • One piece driveshaft I would recommend a dual CV setup otherwise stick to OEM. I have heard most one piece driveshafts cause excess vibration otherwise. The transmission grind I'm quite familiar with. You can try shockproof gear oil, otherwise you need a new transmission. The shifter is extremely simple on these cars. If you want pull apart the assembly and replace the plastic bushing but I doubt that fixes anything. The tail light issue is very common, unfortunately new tail lights are long discontinued. The trunk antenna going up always is because your radio doesn't have a true power antenna control, just remote amp power signal. There is a blank switch plate that you can pop out and install a switch for this or alternatively source a head unit that has proper antenna control. Throttle body sticking you have to disambiguate by disconnecting the cable and seeing if the linkages are the problem or something else. There is a procedure to adjust them, refreshing them is also somewhat involved if that's the issue. I have dealt with many of these issues. Old cars really are fractals of problems. The more you fix the more you discover there is to fix.
