Can The Insurance Company Find Out How Much I Bought My Car For?
By 180 wanabe · Posted
Yeah I would like to try and get a ADM car to reduce issues with insurance. I've decided if I end up getting this car I will set it up to be a sleeper build, leave it looking stock/dad spec on the outside I wonder if you can just drop in the 400r/Red/Z ECU or better still use a flashing tool to copy the map off one. Backup the factory map and then flash the 400hp cars onto the 300hp cars ECU? -
Nah, yeah, nah. Speakers have a nominal impedance of 8 ohm that looks more like 6.4 ohm when measured. The receiver's amplifiers (all channels) are all rated to 6 ohm (I think, it's been a long time since I cared). The real problem is that many modern class D amps have aggressive protection circuitry that cuts off the fun if they think too much current is being drawn. And with my speakers having series crossovers, as opposed to more typical parallel crossovers, and big TL enclosures, they can certainly dip down to lower impedances at some frequencies and that easily triggers the protection. Pioneer receivers are somewhat famous for it, but even Denon, Onkyo, et al, all have many complaints against them across various models. It only does it when listening to music at high levels. You have to be putting your ears at risk to do it. But sometimes I want to do that. If I was serious about using it as a listening room I'd simply upgrade the amp for the front pair to a nice Rotel or something, and just use the receiver for signal handling and processing - although that would be a bit of a pain in the arse too. Have to switch on more shit, pre-amp volume vs main amp volume, etc etc.
This is why you don't get invited to press events. Kodi
For example, you’ll need this approval if: you’re a car enthusiast looking to import a specialist vehicle or an older car you want to bring your vehicle with you when you move to Australia you manufacture or import special purpose vehicles or a small number of trailers each year. Tutuapp 9Apps
