Hey guys sorry for he nrebie post but i'm rather new to skylines. I was just wondering how the Attesa 4WD system works for the GTR? Also is the R32 GTS4 equiped with the system? I know it controls the power of the rear and front wheels. Is there anyway to control it? like a swtich in the car or something? I was told by someone that the 4WD system for the GTS4 'switches around' the power differnential from front to rear based on road conditions. Is this true?Sorry once again for the newbie questions. Any advice is greatly appreciated.
https://www.sau.com.au/forums/topic/14263-attesa-system/
The GTR's AWD driveline is electronically controlled. ATTESA-ETS stands for Advanced Total Traction Engineering System for All-Electronic Torque Split. This is combined with an active rear limited-slip differential. The system monitors individual wheel rotation 100 times per second and can re-direct torque away from slipping wheels. What this means in plain english is that the GTR acts like a rear-wheel drive car most of the time until the rear tyres break traction. Then the torque split is 50-50 front to rear, gradually feeding torque to the front wheels. This is why GTR's are king at launching and for ultra-fast take-off's because the initial slip at the rear tyres prevents the engine from bogging down through too much traction.
The GTS-4 does not use the same AWD system.
https://www.sau.com.au/forums/topic/14263-attesa-system/#findComment-287967
My bad! I didn't explain it properly. The GTS4 DOES have the ATTESA system, However, the calibration of individual wheel rotation is slightly different. Aside from this fact they are essentially the same. Both the GTR and GTS4 torque split is biased 100% to the rear wheels until they start to slip. When the system notices slip, the torque is re-directed and can vary to a maximum of 50-50 front-to-rear gradually feeding power to the front-wheels. To give an example of difference in each car: When gunning it out of a corner the GTS4 is much safer and more forgiving than the GTR. It won't get into such wild oversteer attitudes at such an early - and often unexpected stage. But what would you expect? One's a certifiable dangerous Group A weapon/legend and the other is a chuckable/fun sporty coupe.
https://www.sau.com.au/forums/topic/14263-attesa-system/#findComment-288540
But back to the original question, does any one know about any devices that can control the torque split? I know its a pull a fuse in the r32, but what anout r33 and r34?
I saw an article in autospeed where they modified the sensors, but that sounded pretty bodgy to me. Any other way to control the torque split?
https://www.sau.com.au/forums/topic/14263-attesa-system/#findComment-290374
I actually worked at Nissan in Japan for a couple of years and had some input into the Skyline range.
Naah j/k. I've just read-up heaps on GTR's & had some hands on experience. Farkin Luv Em :uh-huh:
I'm currently saving for an R32 GTR to buy @ the end of the year. Still considering whether to go through with it or not coz of the daily driver aspect and just general concern. I've driven one before but don't know how that'd go on a daily basis. This is why i'm also considering a heavily modded 33GTST. But I'd rather Godzilla coz there's sumpin bout the feel of the car that just does it 4 me.
Btw, Beautiful car Nissaner, I Luv black!:burnout:
https://www.sau.com.au/forums/topic/14263-attesa-system/#findComment-291882
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
