Hello all, I haven't driven my skyline very much for a few weeks and left it parked outside on my driveway. Now I find the brake discs covered in dirty spotted orange rusty dust. Is there any spray or whatever to prevent this from forming? Does the rusty crap damage my brake discs?
Edited by R34 Rampage
https://www.sau.com.au/forums/topic/142637-rust-on-brake-discs/
My discs rust up when i wash the car!! Dont think it does any damage. I just do what is already said, drive around the block normally for a few minutes (not hard braking, or brake dragging etc) and that cleans them up again. If you do find a way to stop it, let me know.
I think its normal, tiny brake particles (some of which are metallic) can always be found on your discs. Run your finger on the disc (after it has cooled down) and youll get some dust on it.
Hence when it rains = rust. Dont think you can do anything about it.
Its even more obvious after washing the car. Happens to all cars, nothing to be worried about.
As soon as you go for a drive, asuming you use the brakes :( it'll come off, nothing to worry about.
    • I have done smoke test and can’t see any leak on high or low side.   checked pump and fluid can flow through. Removed the high pressure from steering and did smoke test and same on low side, no leak.   puzzled. Thinking why if it was all ok it suddenly went as car was off road for a year. Don’t want to disassemble pump yet as i can see fluid / air( compressor) can flow through with no issues
    • Which manifold mate? Meanwhile......Mark is wondering how bonnet vents would look on the NC 🤣
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
