Is Power Fc My Next Best Mod?
drewr33
 Share
Ok guys Ive had my Skyline for nearly a year now. Just need a little help on next mod.
So far the mod lists is as followed:
Full 3inch twin dump, high flow cat and cat back exhaust.
Just Jap FMIC
Boost set at 11psi
Bosch 040 pump
POD
Thats about it.
Now what would you guys recommend my next mod to be? I was thinking Power FC.
With a Power fc what power gains would I be expecting with the above mods.
Anyone got before and after dyno sheets?
Thanks.
Absolutley Power FC.
I've nearly the same mods as you.
12psi..though. (no big deal)
The mid range of the Power FC is HEAPS better than standard.
A more enjoyable/better overall drive than any other mod.
I waited nearly 3 years before getting it installed....including over a year of buying it and storing it in the cupboard.
What an idiot.
Also, next mods you get need a new ECU anyway so just do this one now.
so overall.....Top output should be better, but for me, the midrange was the best bit.
You will NOT be dissapointed.
You have all the right mods to suppport it...Just Do It
adjustable cam gear is only if ur chasing the very last kilowatt
it will maybe give u 5rwkw max at top end and very little midrange
the thing is a lot of time has to be spent on the dyno setting it up
first u have to adjust overlap, then retard/advance each cam independantly, then check out the overlap again...see what i mean - thats a lot of dyno hours (2 at least)
isnt it generaly safe to assume a min of 15% gain over std ecu? i have basicaly same mods except upgraded turbo on my r32 rb20. ive just orderd a pfc and i have cam gears, i would suggest for the sake of it purchase a cheap exhaust cam gear and dial it all in on the dyno at the same time, thats my plan and contrary to the previous post depending on how you set em up, i would expect a slight but cost effective mid range gain...
it will make a diff when matched to the right mods
im just remebering an article on a engine build up that had lots of work already done and cam gears only really gave top end, not much midrange
if u get diff cams, thats a greater diff - but prob not in ur price range :)
 Share
