hey ppls
i've got 2 stock s15 16" rims for sale. There in very good condition with no gutter marks or anything. I've also sprayed them glossy white. One looks 100%, its all white and shiny and what not, the other is like 90% cause it has a few small ripples in the paint... but some paint thiner or woteva will fix them up real good if you dont like my paintjob.. :(
They come with the nissan centre caps aswell.
I believe there the same size, or very similiar to stock r33 rims
oh yeah, theres NO tyres on them.
$100 + delivery :)
Im in melbourne
thanks
https://www.sau.com.au/forums/topic/142657-2-x-stock-s15-rims/
