Thanks heaps guys, if only I had the money.
I was talking to somone in an Import shop (not giving away names) and they told me that the Autech R33 sedan was not able to be complied in Australia because controlled crashes have not been performed on them. Is this true???
https://www.sau.com.au/forums/topic/142674-wtf/page/2/#findComment-2660665
HPI had a story on a black skyline 4 door that had a gtr conversion - this is probably the same. Still, if someone is keen, they should check it out - if its done properly it might still run well.
I'm pretty sure it was in speed magazine, not hpi though i could be wrong.. Pretty sure its the one out of the mag..
https://www.sau.com.au/forums/topic/142674-wtf/page/2/#findComment-2661245
Its not real, thats the one Ernest Parry built a few years ago and yes it was in HPI. Its still missing the few touches that make a R33 GTR sedan different - ie series 3 xenon lights, interior etc. A propper Autech R33 4 door goes for much more than what he's asking.
https://www.sau.com.au/forums/topic/142674-wtf/page/2/#findComment-2662778
there is a ture one up at mooloolabah I have seen it parked there a couple of times but never find the owner :D
is this what u are talking about.....
there is a proper impul version up here yes, had the plates 25.MAT on it, been for sale for ages, but its not a GTR its only a 4 door impul version. with a few tasteful mods.
he has been a member on this site ages ago but havent seen him around for a while.
now doesnt have the plates, only has standard ones on it, i see it most days going to work.
here is a link to it for sale.
http://www.carsales.com.au/pls/carsales/...p;category_id=3
Edited by 85URK
https://www.sau.com.au/forums/topic/142674-wtf/page/2/#findComment-2667983
Ok he just got back to me. It has been made from an R33 V-spec GTR with Autech parts, flared rear quarters and door. Made by Skyline Imports QLD.
VIN is 6U9000ENR33005578
Booya,h yeah I was 99.9% sure it was his old one, used to see it a fair bit so knew the trim/wheels.
https://www.sau.com.au/forums/topic/142674-wtf/page/2/#findComment-2673321
    • So....to find any R chassis part number, get your VIN (will be something like ER33-xxxxxx for you) and go to: https://www.amayama.com/en/genuine-catalogs/nissan and enter it. From there you have access to a web version of Nissan's part system, FAST. It is a bit tricky to get used to, so maybe have a shot and post up what you think.  You can also search by general model but note in some cases your car might have different options so VIN is safest.  On diagram 211 I got 14075-75T16 for Connector, Water Hose If I search for part 14053‑21U10 that you posted, that is also a water hose but not the one bolted to the plenum and 14075‑04U00 is the fitting where the water hose goes into the block.
    • Yeah now we are talking I much prefer coolers in the front middle because it lessens the chance of a small bump to a corner stopping the whole event. I was thinking the AT cooler can move out of the radiator, delete the AT/engine coolant interwarmer and mount a separate cooler with a thermoswitch somewhere further back as is common in racing, that would be one thing. Beyond that, the engine oil cooler is an obvious one to move to the wheel arch, potentially one on each side, but unused space is an issue. I did have a earlier pic with the bumper off but it doesn't show how busy the corners are: DS is full of the auto driving sensors and PS is totally fully of windscreen washer fluid reservoir But ultimately I was hoping to keep the AC, and the water/air heat exchanger is fundamental so it is not just the radiator that needs to be in front BTW here's airflow to the rad as it ran at the track (one horn is gone now and I'll remove the lights next time):
    • your right the maps for Australia came out in 2017 but are 2010 maps. i got the updated maps SD card put it in and it was the same. Same maps in my Brothers Nissan Patrol. 2020 i think his car is
    • Yeahhhh, the costs have killed me. Spent more than the cost of an engine rebuild and it most mostly servicing and a tune lol.
