Im removing my GT2510 off my RB20 and i've basically removed everything except the fluid plumbing, although i still have 2 nuts supporting the turbo onto the manifold.
i have had a quick look at the oil and coolant connectors and would like some advise on how i should remove them before i just have a hack at it.
1) i am a little unsure whether to remove the coolant lines at the fittings on the turbo itself or should i simply cut the hoses and replace them later? (they wont pull off as the hoses are well stuck to the pipes)
2) the upper oil fitting looks well rusted, do i remove it at the turbo itself (which looks quite fiddly) or at the engine?
3) the oil return line looks quite straight forward by removing the 2 bolts on the under side of the turbo. is that correct?
4) should i drain both the oil and coolant from the engine before i begin removing any of these fittings?
any tips or tricks on this will be greatly appreciated !!!!
thanks
Iz.
https://www.sau.com.au/forums/topic/142679-turbo-removal-tips-on-rb20/
dump the coolant, you can leave the oil.
Remove the lines at either the block or the turbo, where ever is easiest. One of the water fittings will have to be at the turbo, the other water and oil line you can get to fairly easily from under the car. Get them on the block if you have braided or flexible lines.
upper oil banjo bolt is easy to get to, use a 17mm socket and extention bar to undo it, the two side water feeds are a bit more fiddly and you need a 24mm spanner for these. undo all fittings at the turbo except for the oil drain where you can undo it at the sump. remove dump pipe and undo the bolts holding the turbo on the manifold and it can now be removed.
takes 20 mins :)
jeez, you are keen :thumbsup: Takes me 3.5 hours.
I find if you remove the turbo oil feed first and the water supply lines fri=om the turbo. The outside one leaning in over the car, and the isside on lying under the car reaching up.
Take off the drain at the turbo (2 bolts) other wise you will have a hell of a time getting the oil drain back on when the turbo is back in place.
be very careful bending the lines. If you do it is a bitch to get them back in.
Also be really careful not to loose your copper washers :)
It is a fairly easy job is you take your time and go easy.
One issue is depending on scenario the std oil feed line is restricted to suit a BB Turbo. If you put a NON BB turbo on you need to remove the line and drill out the restriction in the banjos for increased oil supply.
Cost me a new turbo when I did not know this.
    • Hey everyone, just wanted to let you know about an app I use to track the modifications, repairs, servicing etc I do to my R33 GTR. You might like to use it as well. I'm biased because my son just wrote and released it! But I think you might find it useful to... https://trackmymods.com
    • Hey everyone, been on here for a while, but never introduced myself before. 1st import was a R32 GTS Type M, then R33 GTS, now R33 GTR - each one sold to help pay for the next one. Over the years my son has seen me modify and do changes to my imports and was one of the reasons for him to build an app for car enthusiasts like us. (He can only afford a 2007 Honda at the moment, but he'll get there!) Anyway, bit of a proud Dad moment as he's released an app that I use and you all might like to as well. https://trackmymods.com
    • It will sound tragic and you wished you didn't have 1x exhaust per turbo. There's a reason why most S55 owners change to a single mid pipe.
    • Echo the comments about the well preserved condition it's in. It has the aero bumper too for extra points. Nice car, and please keep it like that! 🙂
    • 1. There are no real performance benefits. It sounds different, and as the pipes are not as large diameter you can claw back some undercar clearance or run lower (if that's your thing). 2. Twin pipes, offering exactly the same cross sectional area as a single pipe** will have higher pressure drop - so will not flow as well. That's because there is more surface area of wall per cross sectional pipe area, hence more frictional losses. ** But of course, it is almost impossible to get 2 pipes that are exactly the same XS area as a given typical single pipe. eg, 2x2" is not the same as 1x 3", although it is close. If the 2x pipes add up to less XS area than the single - it will just be flat out worse. If the 2x pipes add up to a bit more than the single, then it might come out as a wash. If the 2x pipes are substantially more XS area than the single, then it will probably flow a little better. 3. No. Why would there be? What have cats got to do with boost creep?*** ***But for f**ks' sake, please run a cat. 4. If you want.
