  • Replies 40
Posted Images
Thanks for the comments guys. I wish they all could've gotten their own page or two in the magazine.
For those of you who didn't notice here's a close up of the sign that's behind the black 34 GTR in the first pic.
Wilch,
Looks great, I would like to get someing printed, PM sent.
  4DoorWhore said:
wow someone please lower that R34 GTR eeee-gah....
nice pics though... that silver R32 w/ no spoiler is hot!
I do 30,000-40,000km a year in the car, the STD suspension is hard enough so I have not pursued an after market replacement, but yes it would look better about 1-2 inch's lower, and Im sure my track times would also get lowered as well.
Hi guys, again thank you for the comments.
I have put together this collage of one of the only cars I was able to take more than one photo of.
http://www.wbcarphotos.com/portfolio/HPI_S...lage_800web.jpg
I've also taken a few orders already for the poster run that I'm sending through on Friday/Friday night which I should then receive by next week. If anyone else would like a post please PM me.
A3 - (approx. 297mm x 440mm) = $25
A2 - (recommended for images like the one above) - (approx. 610mm x 440mm) = $37
these are proper photographic prints, not inkjet or similar
Larger than this can be arranged as can lamination with a black border (but again these cost more).
Please let me know no later than 5pm tomorrow afternoon if you'd like prints.
Cheers,
wil..
  • 3 weeks later...
Wil,
I really think you should add these shots to your portfolio on your website! You can use my car, too, I don't have a problem with that at all.
BTW, have the prints come through yet?
Cheers,
Nick
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
