I have opinions on plenty of things I don't have first hand experience with.
I've never fallen off a motorcycle with no helmet and landed face first onto the asphalt. But I have seen photos of people who have. Does that mean I can't offer an opinion as to whether its going to hurt or not, because I only saw some pictures on the Internet?
If everyone took that attitude of only trusting what you've personally experienced, we'd probably still be living in caves. Sir Isaac Newton (you know, the guy that came up with the theory of gravity and the basic laws of physics) once said, "If I have seen further [than certain other men] it is by standing upon the shoulders of giants." He didn't feel the need to prove anything to himself - he took the conclusions of others, decided if they were plausible, and ran with them.
Have you personally compared the strength of titanium against steel with a scientifically rigorous test? If you haven't, would you be unwilling to offer an opinion of which is stronger for the same weight because all you've got is hearsay?
Edited by scathing
On topic, I've heard good and bad things about both places. Which is true for almost every workshop.
But both places generally have more positive than negative reviews, so in the end its probably going to boil down to whoever charges you less.
the things you speak of are a little easier to prove as there is a physical element. I am sure everyone knows that when half your face is missing due to gravel rash that its going to hurt, it will only be the level of pain that varies lol As for who is a better workshop, that is a personal opinion, and one which can only be made when both sides of the coin have been tried.
I was just wondering who i should get to install my z32, fuel pump, fuel reg, power fc, turbo and injectors and tune - Advan in silverwater or Croydon racing developments. Has anybody had good/bad work from either???
hitman at race solutions in penrith. very good reliable tune and it wont cost you a 1000 dollars. he does all our cars and the race civic. very good at powerfc
i just had installed my z32, 044,sard reg, and greddy ultimate ecu installed by crd. car made 220rkw at 13.5psi on stock turbo. my pfc had a fault in it so i had to use the greddy, but seemes to be doing the job very well. afr is right on 12 right through the run.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
