The details are below.
Event: Track Night at Wanneroo Raceway
Time: 1830 - 2300 (Scrutineering between 1630 - 1800, driver briefing at 1800-1830)
Day: Thursday 7th December 2006
Cost: $150 (entry) + $97 (L2S CAMS license, $12 admin fees) OR $52 (L2S CAMS day license, $12 admin fees), If you’re a current CAMS L2S license holder and have not competed in one of the No Limit All Street Car Events before a $12 club fee is required on top of the $150 entry fee. This is a once off payment. All bookings are taken to become full paying participants therefore NO refunds will be given as booked places can’t be refilled.
Entry requirements: Minimum of 30 cars, Maximum of 50 cars
Vehicle Requirements: - Road registered/road worthy
- Minimum of 1kg fire extinguisher bolted in a place that it is easily accessible (can be purchased though us ~$65)
- NO loose items.
Vehicle Recommendations: - Fresh high temperature brake fluid
- Decent quality high temperature brake pads
- Good quality street legal tyres
- Plenty of fuel (no service station close by)
- Good condition suspension components
Driver Requirements: - CAMS Level 2 Speed License (this will be on offer on the night)
- Current Australian Class C drivers license
- Long pants
- Long sleeved cotton shirt
- Enclosed shoes
- Certified motorbike/race car helmet
- 0% blood alcohol
Spectators: Spectators are welcome, the cost for entry is $5 per person. STRICTLY NO ALCOHOL.
Food and Drinks: Sausage sizzle and soft drinks will be on sale on the night, price to be confirmed.
Please contact me on the follow email address nolimits@trackskillwa.com.au to put your name on the list for the event.
Please include the following information in the email:
Name:
Car:
Contact number:
Contact email address:
CAMS license Y/N, type:
Fire extinguisher fitted Y/N:
First Time with No Limit Car Club Inc. Y/N:
For more information please don't hesitate to send me an email, regulations for the events will be available soon.
Regards,
Brett Williams
Event Promotions
https://www.sau.com.au/forums/topic/142692-no-limits-all-street-car-events/
Hi Brett,
Had a great night after the early scare. Loved the new semi slicks on a dry race track this time :) an even managed a 58.12sc on the short circuit, not to bad for my second trip BUT got plenty of improvement left (turn 8 :( ). All i can say i will denefitly be going to alot more of these and strongly recommend it to anyone how enjoys driving there car with a bit of zest.
pete :)
ps hope to see you at the next one
Sounds good. Did you end up working out what the little issue was??
Brett.
well i believe so but it's hard to know for sure as it was very strange occurates and i couldn't fault the car afterwards and the instructors like the straight speed the R had even on minium boost hopely have it ready to trash next night event.
brett is it possible to get the membership card sent out or the future track days sent to me as i miss catching up with the lady for my membership card on the night with the dates on it.
pete
I'll be sending out an email with all those details of dates etc.
At the moment the 18th Feb which is meant to be the next event might be canned due to it being the week leading up to Motorvation and we don't think many people will attend.
Brett
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
