Nitrous Laws In Wa
skyliner86
 Share
Hey all
I've had a look round SAU and i cant really find anything to answer my question.
What is the law for nitrous fitted to a street registered vehicle in WA...i believe its illegal but i've heard people saying you can have it installed but the lines disconnected from the bottle. Is this true?
I've seen heaps of cars at shows with NOS which are people daily drivers and wondering what they do to get around cops.
Does anyone know of who i can contact to find 100% correct information?
Cheers for and info people can give me
Try Hyperdrive or Top Racing - the guys there will know what's street legal.
A while ago my nutty mechanic mate had just about convinced me to chuck a 50HP shot of nos in my 33 but my other mechanically minded friend just looked at me and said "SASHA NO it's illegal and it puts a lot of pressure on your engine." Lol so I didn't really take the idea much further
Yep contact the actual govmt agency for confirmation as everyone seems to have different interpretations of the rules and regs. I'd find out what the ADRs say about it and then contact the road authority in WA to see what their view on it is.
To my knowledge it is illegal to have ANY part of a nitrous system installed in a car on the road whether the bottle is connected or not.
Nitrous kit fitted to car is illegal to drive on public roads in WA.
Installations I have had a part in have all been 'invisable'. I don't believe in driving around with the stuff on the road. It's something like planting the foot real hard and breaking the speed limit that you should do at the track.
I fitted my kit on my old R33 gtst and everything was hidden real well. The kit was sold to 2rismo who now runs mid 11's with it and the stock turbo.
I'm preety sure its illegal $10,000 fine I think same as removing airbag steering wheel...as dan mentioned, you can have the set up in the engine bay but cannot be connected to a nos bottle....can try blowing air as you drive..
puff puff~~
subwoofer box has been done before, to conceal the bottle. It needs to be vented. The problem is that driving around with nitrous connected is that in the event of an accident, not even your fault, you may face charges and the insurance company will not cover the cars repair. Not to mention that nitrous oxide is an accelerant when it comes to any kind of fire you may have and the bottle can explode if heated too much by the event of a fire etc.
My 2c is get a kit if you like but, forget running around on the street with it. Save that fun for the drags.
 Share
    • Pretty simple question. I was about to put the transmission back in and thought I pretty much had it lined up when I noticed it seems like the pressure plate isn't flat. I was pretty careful when undoing the bolts both during initial disassembly for cleaning and when torquing them up for installation so this is pretty discouraging. I'm not sure if I accidentally bumped the pressure plate with the input shaft and bent it somehow or if it just showed up this way. Is it possible that there's just something obvious I'm not doing correctly? I'm pretty sure I was extremely careful to make sure the friction discs were seated correctly in the hub, everything lined up, flywheel torqued according to sequence, the little springs all sitting correctly in their seats, etc.  What's the play here? Do I jump straight to a new pressure plate?
    • OK. I can see that being the case. But if you live in the land of "only switching between 4.08, 4.11, 4.36" like most Skyliners, then you never encounter it. Now I perhaps understand why the crownwheel is thicker on some of the smaller numerical ratio diffs. The two stubs being the same (unequal) lengths and just swapped side to side between the different cases is a new one to me. I'm hating Nissan R200s more than ever now.
    • Reason I say this is I have seen broken ones, in drift, drag and even behind a stock Z. I do appreciate most of the time its the synchro's that go.   Trouble with quoting HP is it doesn't really say how strong the box is.  I've not seen many CD00X box's make it past a mid 9(150mph) I have seen about a stock R33 RB25 box's run a 9 too, they all go boom at some point though.   Another clue is they make gearsets for CD00X box's too, wouldn't be a market if they didn't break or have a limit people are going past.   I totally agree it is a strong box, just have to weigh up the true total cost of the conversion vs rebuilding with a good gearset.
    • What makes you say CD009 boxes are not as strong as you would think? I've always been told the last revision (CD00A) is good for 1000whp and I have no issue's believing it when comparing one side by side with an RB25 box. Makes them look tiny.
    • I picked up an open Center with shafts. I was told the Open shafts will fit a mechanical LSD and looking at them. I think they will work. Will update
