well ive polished the pipe that goes to my throttle body.
and removed the seams that are on the pipe so it looks perfect. spent ages with the orbital sander and 800 grit sandpaper, my fingers are allmost falling off. then i buffed it.
anyhow now im goin to sand my cam covers.
heres a pic of the pipe
https://www.sau.com.au/forums/topic/14273-polishing-engine-bay/
you have to do the plenum now!! :D looks awesome man!
i dont know if i would have the patience...
how long did it take for each bit???
i just painted my pipes and the rocker cover... want to polish the cam covers like u have and then the plenum.
Very tidy!
Im thinking of doing the same (but by hand at this stage - might live to regret taking it apart!).
I have same rocker oil sweat seeping between the cam cover and the rest of the block - did you put a new gasket in, use the existing one, or use some kind a gasket-in-a-tube stuff?
Did you need to change the oil to do this or just be very careful while having the cover off?
Cheers :(
RGS
Its hard work but its worth it for the results. Mine looks pretty much the same as MotoX's now.. next step intake plenum.. Lot of work in that one.
I just use the existing gasket as it seemed to still be in good condition. All back together and been for a few long drives and working fine. No sign of leakage.
Oil all sinks to the bottom of the engine, meaning its all bare. The only thing you really have to watch for carefully is no dirt or sanding particles getting into the cam area while the covers are off. Recommend you do the actual polishing a few metres from the car.
well guess what i did yesterday and part of thursday night.
i busted my hands apart sanding this god dam ****ing plenum.
i dont recoment tyreing to do your plenum. its jsut too hard.
its too hard to get off, unless u take the inlet pipes off as well, which u have to refill your coolant. or u can do what i did and spent 2hrs undoing these 5 bolts.
but this is what it now looks like. and my hands still hurt.
i think thats why i had trouble drifting last night hehehe, or it was jsut the rain and the 6L of diesel on the road. dam sliprey roads
why so hard to get the bolts off?? You had acccess to the right tools?
you have to take the left rocker cover off to get properly to the bolts on the right of the plenum as well correct?? Was looking at how it might be done... i knew it wouldn't be easy.
From the result its worth it mate :(
predator666:thanks predator, yeah i took the left rocker cover off, still hard to get too, i used a ring spanner, the plate on the plenum that attached to the Throttle body slices ya knuckles apart.
DJ_L3ThAL: yes theres is a ruber/steel gasket, its easy to take in/out and it is reusable.
jsut re tentioned all ym belts, and i had a boost leak, seems all fixed now.
I used 240 grit sand paper on the orbital sander, then i rub it back till its baby smooth with 800.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
