well ive polished the pipe that goes to my throttle body.
and removed the seams that are on the pipe so it looks perfect. spent ages with the orbital sander and 800 grit sandpaper, my fingers are allmost falling off. then i buffed it.
anyhow now im goin to sand my cam covers.
heres a pic of the pipe
https://www.sau.com.au/forums/topic/14273-polishing-engine-bay/
you have to do the plenum now!! :D looks awesome man!
i dont know if i would have the patience...
how long did it take for each bit???
i just painted my pipes and the rocker cover... want to polish the cam covers like u have and then the plenum.
Very tidy!
Im thinking of doing the same (but by hand at this stage - might live to regret taking it apart!).
I have same rocker oil sweat seeping between the cam cover and the rest of the block - did you put a new gasket in, use the existing one, or use some kind a gasket-in-a-tube stuff?
Did you need to change the oil to do this or just be very careful while having the cover off?
Cheers :(
RGS
Its hard work but its worth it for the results. Mine looks pretty much the same as MotoX's now.. next step intake plenum.. Lot of work in that one.
I just use the existing gasket as it seemed to still be in good condition. All back together and been for a few long drives and working fine. No sign of leakage.
Oil all sinks to the bottom of the engine, meaning its all bare. The only thing you really have to watch for carefully is no dirt or sanding particles getting into the cam area while the covers are off. Recommend you do the actual polishing a few metres from the car.
well guess what i did yesterday and part of thursday night.
i busted my hands apart sanding this god dam ****ing plenum.
i dont recoment tyreing to do your plenum. its jsut too hard.
its too hard to get off, unless u take the inlet pipes off as well, which u have to refill your coolant. or u can do what i did and spent 2hrs undoing these 5 bolts.
but this is what it now looks like. and my hands still hurt.
i think thats why i had trouble drifting last night hehehe, or it was jsut the rain and the 6L of diesel on the road. dam sliprey roads
why so hard to get the bolts off?? You had acccess to the right tools?
you have to take the left rocker cover off to get properly to the bolts on the right of the plenum as well correct?? Was looking at how it might be done... i knew it wouldn't be easy.
From the result its worth it mate :(
predator666:thanks predator, yeah i took the left rocker cover off, still hard to get too, i used a ring spanner, the plate on the plenum that attached to the Throttle body slices ya knuckles apart.
DJ_L3ThAL: yes theres is a ruber/steel gasket, its easy to take in/out and it is reusable.
jsut re tentioned all ym belts, and i had a boost leak, seems all fixed now.
I used 240 grit sand paper on the orbital sander, then i rub it back till its baby smooth with 800.
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
    • Cheers man, I thought the same.   Bit of an update on it all. It was definitely blue smoke, not grey after all. It didn't really smell oily but it was blue after all. Also puffing just the smallest amount on idle with no throttle.   I ended up pulling the intake and exhaust off and there was around 3mm of axial play on the turbo shaft. So I figured we'll that's buggered and sent it off to get hi-flowed at hypergear. Haven't got it back yet.   I haven't compression tested it yet. Had a look in the cylinder and cylinder 1 spark plug, looked a bit sooty but not oily. Then I've just started doing my timing belt because it's age is unknown.
    • In that case it is probably stock. It lives in the navigator side footwell behind the plastic trim just in front of the a pillar.
    • Good question, I don't really know tbh...I'm pretty stock thought, where could I check this?
    • This. I'm confused by the whole discussion. The only reason you would have a car with e85 only if it was track use and you only ever used e85. All other use cases you add a flex fuel sensor, do the flex tune (you only need to do a couple of % and then interpolate the rest) and then you put whatever the hell you feel like including a mix in the tank and it just works. Want a long drive? fill with 98 Want max zoom? fill with e85 Got a half tank of 98 then find e85 somewhere? Throw it in.
