full 4 stud hubs brakes and stub axle setup front and rear
safety21/cusco 6 point full cage - good for street as it follows all roof and pillar lines
navy blue a31 unregistered/uncomplied 88' cefiro... factory 5 spd manual turbo... fresh 8X,XXXkm engine dropped in - gtr 33 cooler, gtr fuel pump, nismo clutch, eastbear cooler piping etc... many mods can come with it - pm for enquiry/package - has import approval so can be complied easily
fiberglass front and rear fender flares universal - arch type... with rubber seals and stainless hex bolts
random other ceffy shit... series 1 tailights with cefiro written in the middle
kei office front and rear coilovers - height and preload adjustable with front camber tops - need rear tops...
Edited by Hella Flush
willing to ship thats no problems aslong as you pay for freight
It might cost a bit to send a whole car up with a cage and coilovers?
