Hi there, I read many topics on various subject but alot of times it refers to the type of car you have, and I have yet to read a post that says "for a R34 GT-4, it would be blah blah blah" etc etc
so i was wondering if I was going to buy something off this site or based on the recommendation of the topics, do I go for those products advertised for R34 GT-T? or GTst etc etc?
I'd like to know the setup of the GT-4 is similar to which other R34? like the GT-V is like a GT-T without a turbo, is the GT-4 the same as the GT-v, only with 4wd instead of rwd?
thanks heaps
https://www.sau.com.au/forums/topic/142797-gt-4-setup/
essentially a gt4 is a gt with the gtr running gear, ie awd (i dont think the gearbox is a rb26 gearbox tho - i could be wrong)
parts for the engine would be for a gt, but drivetrain parts would be gtr (i think thats the way it goes)
https://www.sau.com.au/forums/topic/142797-gt-4-setup/#findComment-2662233
hi there..i understand what u mean when u said anything engine specific would be like for a gt..
but what do you mean by drivetrain parts?
thanks
https://www.sau.com.au/forums/topic/142797-gt-4-setup/#findComment-2662828
rear diff, front diff, sump pan to take front driveshaft, cv joints, all that sort of stuff is the same as what the gtr has
im not sure about the gearbox whether its a rb26 gearbox or a nissan modified rb25 gearbox
essentially your car is kinda the gtr's younger sibling - the handling characteristics of a gtr, but not the power
apart from that , i cant tell you much more - cause this is as much as i no!!
hopefully some other guys will tell u more soon
https://www.sau.com.au/forums/topic/142797-gt-4-setup/#findComment-2662897
hi there mate..sorry for the noobieness of my question.. but what was those rea/front diff do, what's a sump pam and all.. those r not engine parts yeah? those parts r those that lie under the car? what about wheels/disc rotor sizes etc etc if you know the answeR?
thanks mate!!
https://www.sau.com.au/forums/topic/142797-gt-4-setup/#findComment-2663107
thanks mate!!
www.howstuffworks.com
https://www.sau.com.au/forums/topic/142797-gt-4-setup/#findComment-2663228
thanks..
last question.. so essentially..if i wanna mod my car or change anyparts like take part in any group buys.. i need to buy the products that are setup for gtrs?
just so i know which stuff i can buy which stuff i can't buy..
thanks
https://www.sau.com.au/forums/topic/142797-gt-4-setup/#findComment-2663878
    • And if you want more power, more reliably, and cheaper, go get the Aussie RB... The 4L Barra and put that in instead.
    • No cats will keep discolouring the rear bar. Sends white paint a weird yellow stain. Cut and polish normally gets it out, but you'll be doing that every fortnight I found.
    • Both heads will be equally reliable or unreliable depending on what you do to them.  Stock the RB26 head will flow more. You have access to the stock intake ITB manifold on the RB26 cheaply which flows really well(1000hp+).   Arguably more aftermarket support for RB26, though in Aus we love our RB30 SOHC heads too.    The only downsides to the RB26 head is if you have a VL commodore and want to keep the SOHC look.  Where you may have an issue is drilling out the rb30 block for the bigger head studs but if you are building a big power motor you'd probably put bigger studs on the SOHC head too.  This is just about finding a good machine shop, sometimes easier said than done.  RB30 head worked can make big power just like a Rb26 head, so really it actually more comes down to what your preference is for your car.  People now even making billet versions of both.
    • 2630s work perfectly well. There is something to be said for just using the 30 head, as it saves all the pain of the conversion, still makes tons of power, still sounds cool, etc etc. 2630 will obviously make more power again, but the differences are not stupidly big. It really depends on whether you're racing for sheep stations or not. If it's dead serious, then it's a 26 head. If it's just for fun, it could go either way. But the 26 head and the effort to get it set up, etc etc, is part of the fun.
    • I've been building a 26/30 for a few years now. I've had the head built with all the good stuff. I had a 32 gtr but blew it up and yes its all going into a vl but im looking for some advice from some RB nuts on pros and cons on putting a 26 head on a 30 bottom end is it worth it Works are as follows Head -Extensive porting 1mm oversized supertech valves Supertech double springs Supertech valve guides Supertech titanium retainers Tomei solid lifters Tomei 270 x 10.25 cams Head drain Bottom end series 2 rb30 block Cp ceramic coated pistons Eagle rods Romac balancer Oil restrictions  O ringed blah blah spent a fortune And will get a girdle because the 30s arent used to handling that much rpm Nitto billet oil pump Hypertune plenum 6boost mani Refurbed astra pump thats the cover for it in the boot I did have a precision 6262 but sold it because drag car life. Currently building the ass end full 4 link floater rear end with a 2 speed  But the dilemma i have is my mate rekens I should just stick with the 30 head for reliability. Has any one had any issues with mounting the 26 head ie compression blowing gaskets etc. Just looking for some advice from people who have gone down this route. Here's some photos. Blew the oil pump in the gtr and decided to rip the motor out at the time and do a full build only to find it had been a repairable write off so went down this path.
