My car has a very lumpy idle. At 700-900rpm the rocks around and the idle just feels lumpy.
Someone pointed to the fact that this may be a symptom of aftermarket cams.
Does anyone know of a way to check to see if my RB25 has got aftermarket cams? The car came with lots of other goodies on it, so I wouldn't be too surprised if they were non standard items.
https://www.sau.com.au/forums/topic/142867-lumpy-idle/
Nah I havent checked this, but i do notice that at idle my car seems to burn a lot of fuel (black smoke out the exhaust).
I was poking around the engine bay this morning, and didnt notice anything out of place or loose - including the hoses/pipes...
https://www.sau.com.au/forums/topic/142867-lumpy-idle/#findComment-2662462
I've had the car just over a year, and its been lumpy since I bought it. I've had the PFC tuned a couple of times so if there was something wrong (ie. vacuum leak) i think they guys would have picked it up..
It came with:
Apexi Turbo
Injectors
PowerFC
Fuel Pump
etc etc..
I suspect that its got cams due to the chunky mid-range. If I have a look at the cams, is there any way to tell if they are std or aftermarket?
https://www.sau.com.au/forums/topic/142867-lumpy-idle/#findComment-2662807
They should have markings on them
I know HKS ones have a HKS logo and the duration on them, so I'm assuming Tomei and whatever other brands make cams would have it too
I'm not sure about regrinds though
https://www.sau.com.au/forums/topic/142867-lumpy-idle/#findComment-2662813
VCT solinoid
https://www.sau.com.au/forums/topic/142867-lumpy-idle/#findComment-2663161
Mate 1st 3 things ill check are
1) AFR`s on Idle (but seeing your saying its rich removes this but still check they should be around 14.4)
2) Vacuum leak (do you have a boost guage it should read 19 hg)
3) idle air control valve (check if this is leaking not working correctly)
https://www.sau.com.au/forums/topic/142867-lumpy-idle/#findComment-2663282
If it has HKS Cams you will see HKS Cast into the cams by removing the oil cap and spinning it over a few times.
Unfortunately the duration is on the end where the cam gears bolt to and cant be seen easily. Only early HKS cams have them just under the HKS logo.
The tomei cams are stamped with serial numbers on the cam thrust washers. You might have to remove the rocker cover to see this one.
A couple of things to note.
Most GTST's have a baby smooth idle.
A 4'' exhaust will exhibit a bit of a lumpy idle but is more of a burble from the exhaust then engine idle
If cam timing is way out it can give the same symptoms
Probably the easiest guestimation is if your car has unusually strong mid/top end for the mods.
I imported a car a while back and it had stupid mid range even though it was on low boost at the time. I.e wheelspin in 1st and 2nd on 7 psi! Didnt think anything of it. I cleaned the TB and intake with upper engine cleaner a while later and it was running rough. I didnt remember what it originally ran like as I only drove it once and was away for 6 weeks OS so wasnt sure. Got my brother to look at it and he said it had cams, but sounds like the plugs are f&&*ed! Inspected through the oil cap and he said it had tomei markings on it- but there was no mention on the auction. I emailed a copy of the auction sheet and he said "it has tomei cams" but I couldnt translate/understand that part.
Which brings me to my last point. Once I put new plugs in it, ran a lot cleaner and smoother. Iriway and iritop plugs are great!
https://www.sau.com.au/forums/topic/142867-lumpy-idle/#findComment-2665553
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
