My car has a very lumpy idle. At 700-900rpm the rocks around and the idle just feels lumpy.
Someone pointed to the fact that this may be a symptom of aftermarket cams.
Does anyone know of a way to check to see if my RB25 has got aftermarket cams? The car came with lots of other goodies on it, so I wouldn't be too surprised if they were non standard items.
https://www.sau.com.au/forums/topic/142867-lumpy-idle/
Nah I havent checked this, but i do notice that at idle my car seems to burn a lot of fuel (black smoke out the exhaust).
I was poking around the engine bay this morning, and didnt notice anything out of place or loose - including the hoses/pipes...
https://www.sau.com.au/forums/topic/142867-lumpy-idle/#findComment-2662462
I've had the car just over a year, and its been lumpy since I bought it. I've had the PFC tuned a couple of times so if there was something wrong (ie. vacuum leak) i think they guys would have picked it up..
It came with:
Apexi Turbo
Injectors
PowerFC
Fuel Pump
etc etc..
I suspect that its got cams due to the chunky mid-range. If I have a look at the cams, is there any way to tell if they are std or aftermarket?
https://www.sau.com.au/forums/topic/142867-lumpy-idle/#findComment-2662807
They should have markings on them
I know HKS ones have a HKS logo and the duration on them, so I'm assuming Tomei and whatever other brands make cams would have it too
I'm not sure about regrinds though
https://www.sau.com.au/forums/topic/142867-lumpy-idle/#findComment-2662813
VCT solinoid
https://www.sau.com.au/forums/topic/142867-lumpy-idle/#findComment-2663161
Mate 1st 3 things ill check are
1) AFR`s on Idle (but seeing your saying its rich removes this but still check they should be around 14.4)
2) Vacuum leak (do you have a boost guage it should read 19 hg)
3) idle air control valve (check if this is leaking not working correctly)
https://www.sau.com.au/forums/topic/142867-lumpy-idle/#findComment-2663282
If it has HKS Cams you will see HKS Cast into the cams by removing the oil cap and spinning it over a few times.
Unfortunately the duration is on the end where the cam gears bolt to and cant be seen easily. Only early HKS cams have them just under the HKS logo.
The tomei cams are stamped with serial numbers on the cam thrust washers. You might have to remove the rocker cover to see this one.
A couple of things to note.
Most GTST's have a baby smooth idle.
A 4'' exhaust will exhibit a bit of a lumpy idle but is more of a burble from the exhaust then engine idle
If cam timing is way out it can give the same symptoms
Probably the easiest guestimation is if your car has unusually strong mid/top end for the mods.
I imported a car a while back and it had stupid mid range even though it was on low boost at the time. I.e wheelspin in 1st and 2nd on 7 psi! Didnt think anything of it. I cleaned the TB and intake with upper engine cleaner a while later and it was running rough. I didnt remember what it originally ran like as I only drove it once and was away for 6 weeks OS so wasnt sure. Got my brother to look at it and he said it had cams, but sounds like the plugs are f&&*ed! Inspected through the oil cap and he said it had tomei markings on it- but there was no mention on the auction. I emailed a copy of the auction sheet and he said "it has tomei cams" but I couldnt translate/understand that part.
Which brings me to my last point. Once I put new plugs in it, ran a lot cleaner and smoother. Iriway and iritop plugs are great!
https://www.sau.com.au/forums/topic/142867-lumpy-idle/#findComment-2665553
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
