Lumpy Idle
Primordial
 Share
My car has a very lumpy idle. At 700-900rpm the rocks around and the idle just feels lumpy.
Someone pointed to the fact that this may be a symptom of aftermarket cams.
Does anyone know of a way to check to see if my RB25 has got aftermarket cams? The car came with lots of other goodies on it, so I wouldn't be too surprised if they were non standard items.
Nah I havent checked this, but i do notice that at idle my car seems to burn a lot of fuel (black smoke out the exhaust).
I was poking around the engine bay this morning, and didnt notice anything out of place or loose - including the hoses/pipes...
abit more info might help as in how long you had the car and how long have you had this lump idle but as you asked in your post a good way to find out is to remove your cam covers and have a look jsut a few ideas
I've had the car just over a year, and its been lumpy since I bought it. I've had the PFC tuned a couple of times so if there was something wrong (ie. vacuum leak) i think they guys would have picked it up..
It came with:
Apexi Turbo
Injectors
PowerFC
Fuel Pump
etc etc..
I suspect that its got cams due to the chunky mid-range. If I have a look at the cams, is there any way to tell if they are std or aftermarket?
They should have markings on them
I know HKS ones have a HKS logo and the duration on them, so I'm assuming Tomei and whatever other brands make cams would have it too
I'm not sure about regrinds though
VCT solinoid
Mate 1st 3 things ill check are
1) AFR`s on Idle (but seeing your saying its rich removes this but still check they should be around 14.4)
2) Vacuum leak (do you have a boost guage it should read 19 hg)
3) idle air control valve (check if this is leaking not working correctly)
If it has HKS Cams you will see HKS Cast into the cams by removing the oil cap and spinning it over a few times.
Unfortunately the duration is on the end where the cam gears bolt to and cant be seen easily. Only early HKS cams have them just under the HKS logo.
The tomei cams are stamped with serial numbers on the cam thrust washers. You might have to remove the rocker cover to see this one.
A couple of things to note.
Most GTST's have a baby smooth idle.
A 4'' exhaust will exhibit a bit of a lumpy idle but is more of a burble from the exhaust then engine idle
If cam timing is way out it can give the same symptoms
Probably the easiest guestimation is if your car has unusually strong mid/top end for the mods.
I imported a car a while back and it had stupid mid range even though it was on low boost at the time. I.e wheelspin in 1st and 2nd on 7 psi! Didnt think anything of it. I cleaned the TB and intake with upper engine cleaner a while later and it was running rough. I didnt remember what it originally ran like as I only drove it once and was away for 6 weeks OS so wasnt sure. Got my brother to look at it and he said it had cams, but sounds like the plugs are f&&*ed! Inspected through the oil cap and he said it had tomei markings on it- but there was no mention on the auction. I emailed a copy of the auction sheet and he said "it has tomei cams" but I couldnt translate/understand that part.
Which brings me to my last point. Once I put new plugs in it, ran a lot cleaner and smoother. Iriway and iritop plugs are great!
 Share
    • You know how I know I'm getting old? Because I feel this quote jells with me and SAU Forums, ha ha ha. I've gotten lost a few times as I had muscle memory to scroll to where I wanted on my phone and just click, now I'm lost... Ha ha ha     "I used to be with ‘it’, but then they changed what ‘it’ was. Now what I’m with isn’t ‘it’ anymore and what’s ‘it’ seems weird and scary."
    • You don't lose spark if your battery isolator isn't wired correctly and the ECU still has power from the alternator.   Car has an epic wiring problem. Sounds like power connected really really badly in places. Possibly a power pin on a ground pin for the ECU, and constant power in locations that should be switched ignition.   It needs someone good at diagnosing electrical, a good multimeter, and someone with the wiring diagrams to match the engine loom that has been put into the car, and wiring diagrams for the body side of things from the car.
    • Hi folks, what options exist for PNM35 or what models share the same dimensions and fitment for the front top of tower strut brace. I have seen a few options pop up through Google, the Ultra Racing Australia for one. I have seen some eBay ones that claim they fit C34 and M35 but can't find details if to work out if its true. Also found Taiko / TEMA4x4 claim the one type fits: - Nissan Stagea (2-nd gen; M35) 2001 - 2007, - Nissan Skyline (V35, HV35, NV35, V35, PV35) 2001 - 2007 - Infiniti G35, G35X (3-rd gen; V35) 2002 - 2006 But not sure how true that is. Anyone fitted one or know of someone using one and can confirm what does fit?
    • I got the full kit.   The compressor as above is much smaller and lighter.  Also quieter. Bracket is visually mint and much lighter. The dryer and heat exchanger(rad) are one unit. Also smaller and lighter.  Much more room for an oil cooler. The fan I got was a bit Meh and I might change it.   And above all else it is more efficient, tested a good 3-4 degree's cooler than the old system, which is a lot. Disclaimer though - It wasn't a back to back test given different days. It really does feel colder though(always).  And this example is in my car with that crusty looking old compressor, not new vs new
    • I did not need to see this! With summer quickly approaching... Did you just get the compressor with the bracket or the full kit with fan and everything? In what way is different to the old OEM one?
