My r33 gts-t backfires at high rpm when backing off the gas... pop pop pop i have re-gapped my plugs to .8mm too and it didnt happen before that so im guessing its got something to do with that...
Not to sure why but yeah..
M
https://www.sau.com.au/forums/topic/142868-backfiring/#findComment-2662653
According to what I have read so far, misfiring can shorten the turbocharger's life drastically (damage to the turbine blades) and place the entire exhaust system in shock.. it doesn't sound very good.
This doesnt sound good...
Instead of starting a new thread - Does anyone know how to suppress backfiring?
Is it just a matter of tuning or is it usually something more sinister - eg cat?
https://www.sau.com.au/forums/topic/142868-backfiring/#findComment-2662933
your talking about antilag aka missfiring system
Primordial is talking about something else
sounds very normal, nothing to worry about. its a case of running a stock ecu, too much fuel, hot exhuast and this creats backfires or pops, it is more common on warm days because ur engine wiill be hotter along with everyother part in ur car
https://www.sau.com.au/forums/topic/142868-backfiring/#findComment-2663027
Thanks Michael,
This sounds correct.I'm running a PFC so it mustn't be tuned properly? How exactly to you lean out mixtures when throttle is dropped off? This isnt really possible with PFC is it?
Its sounds right though... it just a hot exhaust and too much fuel..
Great for scaring pedestrians tho :(
https://www.sau.com.au/forums/topic/142868-backfiring/#findComment-2663055
My 34 also does this a little bit but its more of a babble gurgle light popping than large backfireing. It did this straight after a power fc and tune. What bov are you using a atmo one will cause backfires.
https://www.sau.com.au/forums/topic/142868-backfiring/#findComment-2663128
if the tune is lean on decel it can do it also. i had a pop at idle due to a vacuum leak, which was making the car run lean.
but just having a big exhaust usually adds a slight pop since when backing off air is trying to force its way back up the exhaust.
https://www.sau.com.au/forums/topic/142868-backfiring/#findComment-2663134
Dude do you run a atmo BOV, or do you have a recirculated one. a while ago i had to replace the headlights on a cop car due to my atmo BOV, thats when i was told to put the stcok recirculation system back on and is misteriously dissapeared. oh yea and i run a big exhaust 3.75 inch straight back with 1 resonator, no cat and a muffler in the end, and i dont pop. have it cheked it might safe you a engine build due to turbo failure. :yes:
https://www.sau.com.au/forums/topic/142868-backfiring/#findComment-2663610
my guess is the problems is caused by blocking the BOV the AFM puts in fuel for air that isnt there. causing a backfire.
try using your plumb back again and see if that helps.
also look for any intake leaks after the afm,
an aftermarket ecu which removes the afm will solve this and much more.
https://www.sau.com.au/forums/topic/142868-backfiring/#findComment-2663905
that's actually wrong... the ECU only dumps in more fuel when your using an atmospheric BOV.... if you've blocked your BOV, all the air still remains in the system and the correct air/fuel mixture is obtained.
https://www.sau.com.au/forums/topic/142868-backfiring/#findComment-2664012
he is running an aftermarket ecu, so it doesnt matter.....!
https://www.sau.com.au/forums/topic/142868-backfiring/#findComment-2664021
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
