Backfiring
Primordial
 Share
PEOPLE PEOPLE!!!!
can we please get the term right
AFTER-FIRE
AFTER-FIRE
AFTER-FIRE
back fire is where you get flames out of your INTAKE
thanksyou ;)
what??
obn topic, i am running the stock BOVs, with PFC, and a safe tune on it. mine backfires quite a bit. it even throws flames sometimes at high rpm. i believe it is quite safe, it is just running a tiny bit rich.
PEOPLE PEOPLE!!!!
AFTER-FIRE
AFTER-FIRE
AFTER-FIRE
thanksyou :)
Technically correct, thanks.
How many people would know what afterfire is though? :happy:
personally I like a good backfire on a gearchange or decel but " hey" thats just me :yes:
If you find it a problem there are a couple of things you can change on your PFC settings to remove or lessen the effect.
Firstly your accel pump settings are set quite high from factory with the PFC. So any slight blip on the throttle pumps in a fuel but little air. This hits the hot exhaust with the usual pop pop crack sound. You can even "make" it do it on a trailing throttle by tapping the throttle lightly on decel.
Dropping these accel back from the 4 or 5 ms factory down to 2 or 3ms improves things.
Secondly the bottom fuel row settings have a big effect on trailing throttle overrun and can by reduced (carefully) to reduce exhaust popping. The PFC does have fuel cut on overrun I know but these bottom row settings do have an effect.
Cheers,
Mike
Hahaha... this is exactly how i've been scaring unsuspecting pedestrians :yes:
Thanks Mike, great info!
I'll give this a try :P
 Share
    • If the event in USA goes ahead will be interesting as it seems the rules will get more cars over here. Apparently the track is laguna seca too. Yeah s15, if I get a the lower dash trims, centre console and change front cross member to standard LCA position will fit clubsprint. See how rules are as i would rather do complete widebody than a bolt on flare to run the 295 with proper clearance.
    • If the car is legal height I can't see it being an issue. Found a thread on reddit that might offer some insight.   I got a ticket from a copper in QLD for my S15 being too low. They had this wheel thing on a stick that they put under the car and it hit my exhaust. Anyhow went to an exhaust shop to get the exhaust tucked up/hung a little higher and I wound the coilovers up a smidge. Don't think I even had to go back to the police station unlike when I got defected for having a carbon bonnet when I brought the S15 from the ACT to QLD and had to replace it and then rock up at a police station and have a yougish female officer who knew nothing about cars confirm that I had changed bonnets. Should have just painted the carbon bonnet yellow to match the rest of the car lol
    • Id like to race in the US i think alot of those track would suit me   For the s15? Youd be stuck between club sprint and the new Open Am wouldnt you depending on how much interior you have left in
    • Been a bit of work to get to this point, definitely a huge milestone for this sub✌️
    • One small step for an R31...one giant leap for a submarine?
