Since swapping a 25det gearbox into my car (originally N/A) the speedo reads exactly ½ real speed. (30kmh = a real 60kmh)
The original non turbo gearbox speed sensor is much too small just to swap so i have no choice but to use the turbo box sensor.
Does anyone know if its possible to make adjustments to the speedo itself to correct this? Like some sort of calibration screw or something?
now the doors lock at 60kmh (30 on dash) and the odometer kms now tick over at ½ the rate which i guess aint a bad thing :P
its probably raised the hicas kick in point to 160kmh also... not sure
any help would be appreciated
https://www.sau.com.au/forums/topic/14287-gearbox-speed-sensor/
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
