I took by rear bar off yesterday to fit a tow bar and found a little rust it hasn't done any significant damage yet and I think I should be able to fix and stop it ok.
My car is a 95 R33 GTSt 4 door with 70,000, Never bent and in visualy perfict condition.
I just thought I would let other R33 owners know about the problem so they can check there cars.
To see the problem you will have to pull the rear bar off.
1.
Remove number plate and undo the bolt that holds the bracket down.
2.
There are three nuts on the inside of the boot on both sides behind the trim and below the taillights you will need to remove these from both sides.
3.
With the boot open there are I think 4 maybe more black plastic plug type clips that hold the top of the bumper on they will need to be removed.
They are a bit tricky I tried levering them out with a screw driver but ended up having to use pincers and just pulled them up until they popped out (I only cracked one)
4. Now you should be able to pull the bar off.
The problem area
There is a upside down L shaped bracket (The one the black plastic plug clip things go into).
On my car there is rust stains that have leached down from behind this and a few bits below it where the paint is bubbling up. It looks like moisture has got in between the bracket and the back wall of the boot.
I recommend all R33 owners check this spot, before I pulled the bar off I had no idea my car had any rust. :P:D
Has any one else had this problem?
Are there any other Rust Hot Spots I should know about?
Any Recommendations on how I should go about fixing it ?
Thanks
also big rust spot
is under the spare tyre in the boot
i got a leaky boot so water has collected down there and its starting to rust
can someone help me with this leaky boot business?
its in my other thread
I own both a VL Calais turbo and a Skyline.
What’s wrong with a tow bar on a skyline?
I’m not wanting to tow a horse float just a aluminum motor bike trailer and two bikes a total of 350 kg.
Skylines can tow fine I have seen them towing boats and one with a small pop up caravan. R33 GTS-t 4 doors have a towing capacity of 900 KG
Hi Burns,
After taking the front right hand gaurd off my car, and the right side skirting, there if a gap near where the skirting is screwed onto, at the front. Which has succesfully stored about 3 handfuls of dirt / leaves for the last few months at least.
There were signs of minor surface rust, nothing major, but I am definatly glad I found it now not later :D
I'd reccomend taking the skirting off both sides and giving it a good clean. Especially at the front near the framework.
The VL is for sale
The tow bar on the skyline cant be seen any way it is all hidden behind the bumper except for the tong bit and I will take that off when not using it.
Thanks for the tip glenmcrae I will have a look while the car is all pulled apart.
The tow bar came from Nissan it is a S14 200sx tow bar and cost me $265 with all the bits and pieces.
I was also quoted $395 for a custom one.
I was told the S14 kit from Nissan will fit on the skylines fine and it almost dose the only problem is that there is a bulge in the lower section of the rear boot wall. this bulge stops the tow bar mounts from sliding all the way in to the chassis rails so I will have to have them extended about 3 inches. My car is a 4 door the 2 door might not have this bulge so it will go or piss easy.
  • 11 months later...
about the leak into the boot issue - if your car is parked on a down hill slope, water pools just under the boot lid (where it is supposed to run out, but on a downhill slope cannot go anywhere). The pooling water slowly leaks through a join in the metal. Hope that helps to explain it.
Well thats where mine leaked.
Mike
Burns,
Mate I would be very interested to see if you could take any photos to share of the tow bar on and off. Interested to see what it would like as this is something that could come definately in handy for me, and I am sure some others would be curious to see what it all looks like. Always another option and something to do.
Cheers mate!
-Alex
  • 10 months later...
Tow bars on a stock r33 turbo would be fine. But once u start playing with mods, the way the power come on aint the best for towing as u could easily rip the ass end out of the car when boost hits.
Thats exactly what I was thinking... but on a 4 door N/A R33 it would look sorta ok.
yeap under the spare tyre is the worst area but the problem infact is caused by the tail lights, the sealent on the taillights have worn out and leaks water into the interior of the boot, and hence the water finds its way under spare tyre wat i did to remove the leak was pull out both rear lights, done easily from the inside of the boot, unplug the wires take out the screws and push the lights out, then find a good sealant from an autoshop and reseal it , but make sure that u clean out the junk of the old worn out sealant 1st, its disgusting, but u will find after applying the new seal there wont be nemore leaks :P and u can easily fix the rust
Another R33 rust area is around the drivers side window wiper shaft, just as it comes out of the cowling under the black plastic escutcheon There is an indentation around it with no way for water to drain. I had to drill out one of the bolts that secure the shaft to the cowling as it was rusted and seized. A small hole drilled in the depression will fix it....
  • 1 month later...
Best rust treatment i know of is cold galv, but kill rust does the same job with a gloss finish, dont know if it comes in a spray though. I usually clean off rust spray cold galv then with a matching gloss
Another spot for rust is the engine bay chassis rails there is a folded sheet that runs along the top and rust gets between seen this on a import that was rejected because of it. They cut out the chassis no. and took all the id plates.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
