Definitely 0 when not running. Without the oil pump running there is no oil pressure.
Depending on age/condition of your motor and the viscosity of the oil you use, you could see anything up to 7/8 or so when cold, and 4 when warm. The 33 I drive practically every day sits on 4 when cruising on the highway, but my old car used to sit just above 2.
If you're worried, put a second oil pressure guage in to compare readings.
hi all, just wondering if this is normal. I just changed my oil last night but this morning i noticed it was all the way to the top when I first started it, it dropped as the oil heated and sat pretty normal. What is the real concern is that when i give it to it, it rises up past half way getting closer to the top. Im only new to the skyline seen been that i have only had it for 2 months. Is this normal?
Can anyone please confirm if it is normal for the oil pressure to rise as i rev harder...when i accelerate the pressure rises and when i push it harder, ie 4000+, it rises higher getting closer to 8. is this normal?
It should rise as the revs rise......
8 seems high though....
What viscosity oil did you use???
Just changed oil.
i use 5-30 and the gauge reads lower now. Needle sits about 4 when hot and running at revs
the dude at the shop wouldnt let me leave with the oil i wanted...he gave me 20-60...i thought this was wrong but he assured me it was correct. would this be throwing it high? im going to the drags tonight and dont want to blow a head gasket...
i think the oil for stock rb25det is 10-30 or 0-30, not sure if its the same for the non-turbo engines, i just got magnitec 10-30 for mine and its rises with revs and it still runs smoothly (though it doesnt rise up to 8).
Be a bit thick wehn the oil is cold.....
should be fine once warm though......
A 30 grade (hot) oil, ie X-30, is basically designed for the cooler conditions in Japan. Coming summer in Oz, I would think you could probably run a slightly heavier oil, like 10-40. Maybe 20-60 is getting a bit too thick.
gues i wasted $35...damn im going to buy some oil at lunch and go home to do the fastest oil change in history. Oh and when i sell it i can say i change the oil daily....engine care is what im passionate about....i even put in one of those engine tune up things....damn
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
    • Ah yep. I asked a auto electrician about getting a cheap rebuilt alternator vs a new one. He also said he used to it back in the day but it ended up costing similar to what a new one would and recommended getting a new one,.
