Can't you do it yourself?
Its not really that hard to do, it was the first major thing I did to my car on my own. I don't mind coming and helping after exams either if you get stuck.
What FMIC have you got? just a china hybrid copy?
oh really, yeh i was thinking bout asking for help as i dont feel confident myself without instructions :yes:
id put in a carton of your choosing for the time :)
yeh its a hybrid copy, the seller assured me it fits good and other buyers rated it, but thats yet to be seen i guess.
https://www.sau.com.au/forums/topic/142965-fmic-fitting/#findComment-2663975
My intercooler was a custom job that the previous owner gave me. It just hooked straight up to the stock piping so I didn't have to run a crossover pipe or anything. The crossover pipe isn't that much of an issue. IIRC the only things you need to do extra is chop the radiator fan a little so it clears the pipe and cut a hole for the piping. To do the hole you need a hole saw, the GTR and GTS-T chassis is the same so there a place all setup to cut.
The reo (front re-enforcement bar) and front bar need to be cut to fit the FMIC in there, its nothing too major that can't be solved with an angle grinder or jigsaw.
If you work fast you could get it done in under a day, mine took me a day and a half being my first time and all. If you do a search I'm fairly sure there are threads with pictures (might be for R33's but its virtually the same) for installs.
Give me 2 weeks and bottle of bourbon (not a beer person :yes:) and I'll come help you out.
https://www.sau.com.au/forums/topic/142965-fmic-fitting/#findComment-2664049
Give me 2 weeks and bottle of bourbon (not a beer person :)) and I'll come help you out.
sounds liek a deal mate, ive got all the necessary tools !
wats ur poison ? cougar, jim beam ? :P
https://www.sau.com.au/forums/topic/142965-fmic-fitting/#findComment-2664074
wats ur poison ? cougar, jim beam ? :)
buy him the sphincter of the universe its better :P
or try x speed top racing hyperdrive imports101 amongst a good many other places that can do it
https://www.sau.com.au/forums/topic/142965-fmic-fitting/#findComment-2664100
haha ill let him, decide :)
yeh i asked hyperdrive for a quote but they wont touch a copy cooler, fair enough i spose.
after that i asked extreem machines and they wanted about $400, other place said $380. I havnt shopped around a WHOLE lot, thought this would be quicker way to find out :)
thanks for reply though :)
https://www.sau.com.au/forums/topic/142965-fmic-fitting/#findComment-2664144
no a standard one
but they are good upgrades for rb20's
i was just making a point that the money you save from installing your fmic means you can buy other goodies.
yeh exactly ! :)
will go towards injectors or fuel pump...or AVCR...or power FC :S
https://www.sau.com.au/forums/topic/142965-fmic-fitting/#findComment-2664395
I can remap R32 ECU's aswell (useful arn't I? :P)
Go halves with tiesto in buying me a wideband and I'll do it for ya :)
haha whats a wideband, how much are they ? my guess is a lot ?
will need a remap at some point though
so might need your services :)
https://www.sau.com.au/forums/topic/142965-fmic-fitting/#findComment-2664434
haha ill let him, decide ;)
after that i asked extreem machines and they wanted about $400, other place said $380. I havnt shopped around a WHOLE lot, thought this would be quicker way to find out :P
Seriously, i would not use Extreme Machines. Not going into detail but if your going to use a workshop, find another one. Just my 2c
Also, isn't Paul at Autoworx in wangars supplying and fitting fmic for around $900 or $950?? Anyone had him fit one? Are the intercoolers any good?
https://www.sau.com.au/forums/topic/142965-fmic-fitting/#findComment-2664850
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
    • WRXs are a pure pleb boring car these days. You need to get an STI to even get close to what a WRX used to be.
