dont chop the end of the fan blades its a big no no it will put the fan out of balance and f**k it up.. do what i did and buy a longer silicon hose and raise the pipe up
if you dont cut it straight... i cut mine so did every other person i know with a 33.. no biggie just popped it out and disk sanded it into a new custom shape haha... as long as its all symetrical you cant go wrong.
A friend of mine had one fitted at Autoworx.. they sell a full kit for $550 or supply and fit it for $990. he doesn't chop the fan like most installers do and does a really neat job cutting around the frontbar which is the most time consuming part of the job.. he has details on his website at http://www.autoworx.com.au/accessories.htm :spank:
Trust this guy! He's practically a doctor!
My fan wasn't cut during the install of a front mount.
forward facing plenum + electric thermo-fan FTW!
you shouldn't have to cut the blades, if you do, chances are the piping is going to be dodgy and cause other problems (the rolled lip isnt big enough and the cheap hose clamps either snap, or slip off the small rolled lips :blink:)
you shouldn't have to cut the blades, if you do, chances are the piping is going to be dodgy and cause other problems (the rolled lip isnt big enough and the cheap hose clamps either snap, or slip off the small rolled lips :happy:)
fan looks attached to the engine...belt or crank driven by the looks of it
there is 4x 8mm nuts holding it onto the pulley for the water pump. :happy:
unbolt it off there, and run a electric thermo-fan instead!
i just did that with mine.. just wating for the fan to arrive now.
how much was the elec thermo fan?
