firstly what is the difference between bar & plate cooler and tube & fin? what are the performance gains/losses? also i will be upgrading my intercooler shortly and am after a 600/300/100mm core size with 3" end tanks. where is the best place to get one of these? all i can find is kits for various cars. not after a cheap one either. thanks..
https://www.sau.com.au/forums/topic/142985-intercoolers/
search, search, search
its been covered a million times before
the main differences are drag vs track use
both have advantages and disadvantages for each use
what core do u currently have and what do you hope to achieve?
https://www.sau.com.au/forums/topic/142985-intercoolers/#findComment-2664116
Im after a FMIC upgrade from stock on my R33. I have read all the links above and still cant seperate them. The bar and plate seems to be easier to get my hands on and cheaper. Im after a cooler that is good for a couple of runs at the drags but also is being effective to cool over long periods of driving, as i drive an hour to work and from work every day. This heak soak mentioned for the Bar and plate, is it going to be an issue over say a 2 hour drive? is it still better then the stock? Im just after something for Around 200kw, bit of drag, but more importantly something that will work best for everyday use. Thanks!!
https://www.sau.com.au/forums/topic/142985-intercoolers/#findComment-2665889
nismo god after reading the trhreads i can safely say you would be after tube and fin. bar and plate should definately out perform the factory cooler.
paulr33 u think so? what the problem with going too big? can get a good price on a second hand hks one 600/300/110 but seems a lil large. just dont want to have problems down the track and have to change piping etc..
https://www.sau.com.au/forums/topic/142985-intercoolers/#findComment-2666388
If it's for dragging (and you're going to enjoy trying to get 400rwkw to the ground) then throttle response is less important so bigger piping would not be a hinderance in that respect and can only be better in terms of flow.
But... (and I am purely talking out of my arse here).. the restriction of the system is only as much or little as the most restrictive part. In other words, what plenum and throttlebody are you using? Don't bother going any bigger than that.
Also I think that changes in restriction aren't helpfull either. Ie, from restrictive afm (for egsample only) to big piping to small throttle body. You might as well have had piping the same size as the smallest one of those 2 in the first place.
And finally for general reference; Bar and plate = cooler, tube and fin = flows better. You trade one for the other.
https://www.sau.com.au/forums/topic/142985-intercoolers/#findComment-2667604
spend the money elsewhere
Agreed, i think most of these 600x 300x 76 cheap intercoolers really are fine for 600hp. ive made 327rwkw with a stuffed r32 gtr cooler(looks like some kids ran their finger along all the fins)Realistically they are all basically similar, about 10 times bigger than the stock one so none of these would be too small.
https://www.sau.com.au/forums/topic/142985-intercoolers/#findComment-2667679
When GTR's with stock coolers make a lot more than 350rwkw pretty easily.
I reckon it leaves the door open to anything that size or bigger will do.
If your dragging (auto) then it really wont matter, manual it might more-so.
https://www.sau.com.au/forums/topic/142985-intercoolers/#findComment-2668801
abo bob currently i am using a greddy plenum with a rb25det throttle body (need the greddy adaptor). there is a pic attached. the thing i am worried about is the piping and throttle body (2.5") being too small as well as the cooler. dont want to get the thing going then realise its not cooling to the levelit should be..
https://www.sau.com.au/forums/topic/142985-intercoolers/#findComment-2670294
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
