Recently noticed a small pool of coolant under the car everytime I park it - it drips down from near the gearbox but originates from somehwere above that from what I can see i.e. at the rear of the engine/firewall somewhere????
I've been under the bonnet, under the car, everywhere but I cannot pin point where the fluid is coming from.
It is a reasonably small leak but it is getting worse. Luckily it hasn't lost enough fluid to overheat just yet so I've just topped it up for the time being.
Any ideas where it might be coming from?
Cheers,
Tay
https://www.sau.com.au/forums/topic/142997-wheres-this-coolant-leak/
Nothing I can see though - which guarantees it's gonna be a bastard to get to right?
Hmmm under the plenum maybe......will have another look.
Better off taking to a workshop so they can get to it with a hoist?
I don't have the time to be messing with this thing. Estimate on hours x $80!!!
Man this car is starting to give me the sh!ts - asthetically and mechanically spot on but the little niggly things drive me nuts. Leaks left right and centre.
I have had coolant leaks, but thats due to a rusted welsh plug. I believe that it might be wise to just check to see that all the plugs are ok in the car - just to be safe (welsh plugs are there for each cylinder - am i right?).
Good thing you found out about it - I was driving the car, didnt even realise that coolant was leaking - was on empty by the time i got home one night, and the temp guage just shot up - boy did I feel stupid for not checking the leakage.
i had the same issue recently, took me bloody months to figure out.. turned out 2 or 3 out of the 10 or so bolts that hold the water pump on werent on tight enough. You could see little bits of coolant where the gasket goes, and if you looked close enough you could see a few of the bolts were sticking out abit.
I can see an hear mine at the back of the engine behind the plenum. As the pressure dropped after the car was turned off it started spraying out. I lost a lot of coolant after that, I'll have to try and get it booked in somewhere soon too :P
Just been told by Hyperdrive that I have a similar problem to Tay and if the plenum has to come out theres a lot of labor involved and could be a $600 job. Hopefully its just a starter motor out job....
Damn GTR raping our wallets again :P
No haven't got the car back yet. When they pressured it up we had a steady stream of fluid flowing from under the plenum towards the back of the motor.
Pin-pointed the hoses by the sounds of it and they'll attemp to get at it today (when hoses arrive) by dropping the starter motor.
Should have it back today - I'll keep you posted.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
