Recently noticed a small pool of coolant under the car everytime I park it - it drips down from near the gearbox but originates from somehwere above that from what I can see i.e. at the rear of the engine/firewall somewhere????
I've been under the bonnet, under the car, everywhere but I cannot pin point where the fluid is coming from.
It is a reasonably small leak but it is getting worse. Luckily it hasn't lost enough fluid to overheat just yet so I've just topped it up for the time being.
Any ideas where it might be coming from?
Cheers,
Tay
https://www.sau.com.au/forums/topic/142997-wheres-this-coolant-leak/
Nothing I can see though - which guarantees it's gonna be a bastard to get to right?
Hmmm under the plenum maybe......will have another look.
Better off taking to a workshop so they can get to it with a hoist?
I don't have the time to be messing with this thing. Estimate on hours x $80!!!
Man this car is starting to give me the sh!ts - asthetically and mechanically spot on but the little niggly things drive me nuts. Leaks left right and centre.
I have had coolant leaks, but thats due to a rusted welsh plug. I believe that it might be wise to just check to see that all the plugs are ok in the car - just to be safe (welsh plugs are there for each cylinder - am i right?).
Good thing you found out about it - I was driving the car, didnt even realise that coolant was leaking - was on empty by the time i got home one night, and the temp guage just shot up - boy did I feel stupid for not checking the leakage.
i had the same issue recently, took me bloody months to figure out.. turned out 2 or 3 out of the 10 or so bolts that hold the water pump on werent on tight enough. You could see little bits of coolant where the gasket goes, and if you looked close enough you could see a few of the bolts were sticking out abit.
I can see an hear mine at the back of the engine behind the plenum. As the pressure dropped after the car was turned off it started spraying out. I lost a lot of coolant after that, I'll have to try and get it booked in somewhere soon too :P
Just been told by Hyperdrive that I have a similar problem to Tay and if the plenum has to come out theres a lot of labor involved and could be a $600 job. Hopefully its just a starter motor out job....
Damn GTR raping our wallets again :P
No haven't got the car back yet. When they pressured it up we had a steady stream of fluid flowing from under the plenum towards the back of the motor.
Pin-pointed the hoses by the sounds of it and they'll attemp to get at it today (when hoses arrive) by dropping the starter motor.
Should have it back today - I'll keep you posted.
    • 2 does "sort of" applies, maybe......but looking at what parts would be needed for the swap to get engineered, registered, and insured, and basically that's everything under the car, the modifications the make it legal would be problematic and horrendously expensive, all for a street car that just cruises around and hits a few twisty roads on the weekends Also, from looking at the NSW rules and Regs, with all modifications that is required just to make the car safe and not twist itself to pieces, and then actually get registered for street use, may still be impossible nowadays As for 1, when you add in a fresh engine, fresh transmission, rear cradle and diff, tailshaft, suspension, brakes, cooling, and all the other fabrication required, your probably looking at up to $100k to do it right, all for a 20 year old MX5 that is over engineered and you would never be able to actually use the power it has on the street, much like your beastie, which I love, but you actually track that thing and can use all of its powers in anger, in a safe environment  Hell, the old Bogan Cruise Ship had more power than I could use on the street, and in hindsight, I went a bit silly on that thing, it didn't really need the 500hp it had for what I actually used the car for, it was fun, but basically unusable on the street if you value your licence  As for cams, yeah, I'll probably book it in for them to get installed and tuned soonish, like next month after MX5 Mania are back at work....... and yes, I've already sent a email to bin the turbo quote and quote instead to install cams and a new Fluidampr balancer that will suit the 2.5 better than the OEM 2.0 balancer that is swapped over for the 2.5 install, as the balancer needs to get pulled to time the cams it's a while your in there sort of thing I did think a bit about flex fuel for a laugh, but being na, and no where really around locally anymore to get E85, I've binned that idea, so no sweet sweet corn smells are set for the car I wish E85 was more of a standard fuel, it's better for the environment, better for tuning, plus that sweet sweet smell we all love As for fitting in the family, that's not needed, as everyone in the family already owns a car that can seat 5 humans comfortably enough, the MX5 is "my toy" As for buying a car that is already built, nah, I would rather pick and choose my parts, I enjoy the process, and in the big picture, the additional cost is well worth the enjoyment, and the occasional frustration, I get out of doing it, albeit with other people spinning the spanners, and me, just paying the invoice 🤣
    • Excuse me, but 2) does apply 1) Would also apply if you consider how much is spent in the alternatives. Also there's the option of 3), buy one pre-built that you can put your family in (it's me, it's my car)   That said, I went on a ~500km drive the other day. I didn't use anything more adventurous than 3rd/4th gear at about ~3000RPM and 50% throttle and I was going as fast as anyone has any sense doing on a public road, with enough grip to the point where I didn't want to go any faster. I was obviously under the limit of the current car etc etc. MX5 with 2.5 N/A to achieve the same speed would be more fun for any road scenario. Maybe consider cams. I wouldn't boost it. The use case is just not there and it won't actually make the car more enjoyable unless you really do plan on wringing gears from 1st to 3rd (at least) at 100% WOT on a public road to 150+kmh.
    • Great if: 1. You had all of the money for everything else that is required  2. Lived in a country where you could actually do this and drive it legally on the road Sadly, neither applies to me As for the turbo, I am having second thoughts, mainly for engineering/registration legality reasons and insurance  Not saying I've finished doing stupid things that I probably should do to the MX5, but boost, and V8 engine swaps isn't on the cards Strange, but true
    • I like this page, better than that silly turbo kit   https://v8roadsters.com/product-category/engine-conversions/engine-conversion-lsx/engine-conversion-lsx-nc/
    • That would be my Shoei helmet
