This is the question that current faces me. I have a custom 3inch exhaust system end-to-end, & also a 'complianced' cat which sits in between. Do I get a 'hi-flow'cat? or do DIY using broom stick method to remove the guts of the cat!!
I am interested in hearing people that have done this? Did you experience or notice and problems after? I note 1 persons previous comments on backfiring..
People have told me that if I were to change my cat, to hi-flow, I would notice a big difference in power. Wouldnt removing the guts of the cat make this the ultimate 'hi-flow'.
I note that many people have bought either the Catco or MetalCat during previous group buys - so I am sure there would be interest out there?
It's highly illegal and quite dangerous to remove the internals of a cat.
Cats are designed to flow.
If you gut the cat using the method you have suggested, it will interupt the flow, not increase it.
However, if you would like to find out first hand, and risk a massive fine, as well as risking inhaling the carcinogens contained inside the cat, then by all means go for it.
:laugh:
Unless it's a track car, get a proper high flow cat.
there has been a few threads on this.. some even went as far as to dyno the difference from highflow cat to a straight through to busted out cat, the best was a pipe (straight through) then the highflow then the busted out cat.
I have looked everywhere for the link - could you please tell me where I can get this information you mention.
greatly appreciated.
i remember reading a very detailed thread on this - basically u dont want to do it coz its a crazy $10000 max fine or something like that...
and cops can tell by tapping on the cat if its hollow or not...
This makes sense because the compliance cat probably had a 2.5in inlet and outlet. The two step changes in cross section where it bolts up to the rest of the system will hurt flow, as turbulence is created up and downstream of the section change.
The original poster should bite the bullet and get the catco or metalcat. Better performance, no fines, and wont screw up the environment. Reaming the cat is the way of the bogon....you're better than that.
Rgs,
Kot
Edited by MrKotter
I recently went to get a tune and found out my cat was restricting my power i then asked "could you just gut it" the mechanic then told me that they normaly put a straight pipe right through..(didnt reccomend it)
long story short. he gutted it for me and got an extra 5kw out of it.. but its just a temp thing im recivein my new 3" highflow tomoz.
    • I know it's an entirely different engine, but I noticed practically 0 difference removing or adding 2x 3in (5inch body) 400cell cats (one in each bank) with regards to sound. So changing the cat to change drone I suspect will have very very, very, very, very, very very minimal impact.
    • 200 cell cat will probably help. Do you have room to tee off a Helmholtz resonator anywhere along the exhaust? These can do wonders for drones, with a little experimentation with regards to length.
    • The car revs up through the gears much better/faster now, and fuel consumption doesn't really seem to have be affected either on a Hwy cruise, which wasn't expected  The FAB9 intake manifold has been problematic sourcing though, I've contacted Plasmaman to ask about their intake, which you can get different runner lengths spec'd, and, their different options for throttle bodies  The only real physical drawback with the Plasmaman intake is how to connect it to my current OEM style airbox, as FAB9 make a OEM style back half of the airbox to suit the larger diameter throttle body, and all that is required is a 30°bend silicone pipe to mate the throttle body to the airbox Car also goes in for some exhaust work in a week or so to fit the biggest resonator they can fit clearance wise in the front pipe to help remove some of the drone, there isn't alot of realestate under there, a rough guesstimation is it will only be about 3-400mm long and maybe 90-100mm diameter, and with a 60mm exhaust that doesn't leave alot of space for the internal volume of the resonator to do its thing I'm thinking I may need to bin the "high flow" 100 cell cat for something a bit more substantial, yeah, and restrictive, like a 200-400 cell, to help, but, I have ample room for a really large bodied cat to replace the current one which has around a 4" diameter body I may look around in the recycling bins and see if I can find a massive newish cat that was "replaced" with some new full exhaust system that the local exhaust shop in Western Sydney is doing
    • Hahah look at that smile 😂 Just like those ones on IG where they compare the husband in family photos vs husband going fishing lol. I don't think I'll participate this time, clutch isn't in and also the last time I went there were too many numpties on the cruise sessions. Nearly caused a few accidents holding up people and a few guys initiating massive kerb to kerb drifts with heaps of cars right behind them. Not to mention, there were guys on the track session using it as a power cruise session.
