You could put a supercharged big block v8 in a silvia if you really wanted. Anyhting is possible.
Do you mean, will it just drop in? Will I be able to register it? More info required with your question.
just wondering, is it possible to put the R33 engine into something like a S13 onwards silvia?? i was thinking of doing one up as a project car is all
Yes its possible and has been done. Hell even an RB26DETT has been shoved into an S13 before with good results. You will need to enquire about its legalities and what it needs to be engineered etc from your respective state.
The RB into Silvia swap is not uncommon. In fact, it's to the point where it's not really unique enough for some people. Hence the birth of the Nissan V8 into Silvia conversion, but even that has been done a few times now...
See http://members.iinet.net.au/~dcollins/silfiniti/ for one such example.
the only reason i would undertake this is because im not a big fan of the 4cyl and i love the 6 cyl in the skylines. would it b worthwhile doing this or just spend the money on doing up the engine thats in the silvia??
  • 2 months later...
It sure can be done. I had a RB25DET conversion in my 180SX.
By fitting a skyline crossmember from the R32/R33 the RB motor will bolt directly up using the nissan mounts. You should be able to get out of it for around $5k-$6k all up. That's if you do a fair bit yourself.
It doesn't mess up the handling too much. Maybe if your building a drifter, but for a fast street car and occasional track day car it delivers awesome punch and torque!!!
After going through one though, it's alot of work and you can get similiar power and results from going sick on your current engine.
(that is unless you have a NA CA18DE or SR20DE already!!!!)
  • 2 months later...
S13 have good balance why put a RB in the front.. look my car has an iron block on the bonnet..
FWD silvia. ahahah that was gold
Why not?
It doesnt really throw it out that much, but for proper drift you will understeer...
But if you want to go fast you have yourself a lightweight skyline :santa:
Do it! :lol:
Iv'e seen a v6 out of the 300zx(90's model) in a silvia, it looked like there was more room round the engine than in the Z. Don't think there are too many unqiue Nissan conversions left to do these day considering how easy it seems to be to interchange the engines in the skylines etc., even the factory put 4 cyl engines in R32 Skylines for the extra cautious driver...
Oh, and for those of you that don't really now this engine... and where thinking... 'that engine looks east-west' therefore fwd... Its just the intake that looks like that. It is still rwd, and the engine is north-south facing :)
  • 4 months later...
I would love to see a V8 (Nissan or other) in a R34 GTT. The burble and rumble of the 8 would go well with the aggresive looks of the R34.
thers something similar thats been done. search for 'GT Autosound Drift' or something along those lines in youtube. ls1 in a gtt i think
here u go:
    • Just checking, when we are talking about high temp fluid, are we all referring to DOT 5.1? I haven't had any issues with changing it every 2-3 years.
    • Yeah that is still true AFAIK.....good brake fluid should be changed annually because it absorbs water faster which is more often than most mechanics would do it. There are cheap tools that check water% in brake fluid if you all scientific about it. I for sure would (do) run good brake fluid in anything that even casually saw the track like Murray said; avoiding the risk of "exciting" fade is worth it
    • Well, back in the day..... "race" fluids, which were essentially only really "high temp" fluids, used to absorb water more readily. So they really needed to be changed more often anyway. The coincidence of that being directly necessary along with it being what racers would do as a matter of course was just fine.
    • Does the high temp fluid degrade any different over time compared to normal one? That's one thing I've always been wondering. Because a track car is going to get the fluid flushed probably way more often than every two years and will see less kilometers driven. I would think the requirements are different. I'm running Motul RBF 600 in mine. Was recommended by my mechanic before a trackday and I've stuck with it since. Hasn't seen the track since but I've kept buying and using it for servicing anyway.
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.    OH, a quick side question - would you use brake fluid from an opened container even if the lid has been on? Eg, if you have a bottle that you opened last time you flushed, it's been tightly closed, is it still good?
