Hey guys/girls....there maybe one...
anyway. My ER34 is off the road for 3 months..along with my driving habits (guess why *cough*), Im wanting to make my engine alot more revvy (not so much past 7/8k) buy more from idle - redline speed.
Im already working on Lightweight flywheel + Carbon tailshaft + lightweight rims, and general weight removal throughout the car.
Just want to know engine wise, what can I do to make my engine rev alot faster.
My goal is 220RWKW, with as much reponse, torque etc i can get out of it. Its for the touge, the touge, the touge. So my biggest enemy is turbo lag.
I already have:
(although barely any of this is to do with engine response/revs)
3" Exhaust, Bride bucket seat, Carbon bonnet, coils.
https://www.sau.com.au/forums/topic/143064-i-want-my-skyline-to-rev/
  • Replies 118
Get a super responsive turbo, like the APEXi RX6 B. I have friend here with a S2 GTST with a RB 25 and that turbo, it moved like crazy. what i would suggest is getting your rotating assemly lightend, crank machining, lighter pistons, lightened pulleys, a good damper. get some cams to make the midrange - high end power, get a ECU that can control your VVT, thats about what i can pul out of the hat for you.
reduce the reciprocating mass
so, as you said lightened flywheel, carbon tailshaft
also, im not sure if you can get lightweight pulleys for the rb25, but if you can, get some
are you rebuilding the engine internals?
Want revs huh? Just drop a PFC in it and set the rev limiter to 12,000rpm :laugh: Your engine will love you for it...
Nah seriously,
* Pod
* Turbo Upgrade (hi-flow?)
* Cams
* ECU
* Fuel Setup
I wouldn't be too concerned with the weight reduction stuff... if you're aiming for 220rwkw; you'd be able to piece a setup together that will enable you to pull enough power to move that mass.
if you are serious, which i dont think you are then
strip the boot interior
strip the rear seat interior
change the rear diff gears
heavy duty clutch
powerfc & boost kit & tune
hiflowed turbo
split dump exhaust
fuel pump
cold air intake kit
fmic
suspension complete overhaul (to get the power down)
-shocks, bushes, camber, castor for all 4 corners & pineapples for the rear
good rubber with suitable pressure
The question he is asking is quite a good one.
Notice he said 'not so much past 7/8k but, from idle to redline?
He's not trying to rev the motor to 14,000rpm. The goal is 220rwkw as a peak value.
Cover;
Reducion in rotational mass
Increasing the average power across the desired rpm range,
Reduction in total mass (power to weight)
and finally optimised gearing
is a short answer.
The power goal you have is sensible but, one last thing is getting an optimised response monster's power to the ground. You will need to look at tyres and suspension too.
PM for some more info if you like.
Keep the clutch pedal depressed - I find the engine is extremely responsive to revving by doing this. :)
lol, i had that happen, it was amazing ;)
Anyhow, on topic, if you read the sticky FI Guide, you'd come along to this thread which covers more than just the topic at hand, but more surrounding issues aswell.
And old thread, but still a very very good one, so read the whole thread
http://www.skylinesaustralia.com/forums/in...?showtopic=9445
:ninja:
If you do decide to go for a rebuild, as well as getting lightened internals you might want to up the compression as well.
You only need low compression for big boost - if you're running low boost then a higher compression won't matter so much, but you'll pick up more power and response. Especially off-boost.
I don't know if it'll make the engine more willing to rev to redline, but it will make the engine pick up in the midrange (which is what you want for touge).
havent yet sky 34, just working towards it.
Rear of boot + rear seats/ rear interior are gone.
rear speakers are gone, passenger door internal pannels are gone,glove box is gone.
So would anything like cams/cam shafts help response?
If i did get a hi-flo, i wouldnt want too much that would increase lag.
ATM im more wanting to work on engine response throughout the rev range.
Gear ratio/diff ratio sounds awesome too.
i think what i want is the engine to rev faster, even if in neutral. i'd like to work on the engine to learn more. love to rev from idle-7/8k in 1 second... mmmmm F1 response.. u know what i mean..
i hope.
thanks for the other suggestions, open to more. will be looking at that thread as suggested.
to blip the throttle in neutral, you need to lighten pulleys, flywheel etc, remove anything draining on the engines spin eg. the A/c and perhaps rebuild with lighter, fully balanced internals. I doubt it would be anything like what you are finding in gt4 though...
if you want to do it in gear, you need everything as above, but more power too. It can only rev as quick as it pulls.
or buy shit rear tyres
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
