Hey guys/girls....there maybe one...
anyway. My ER34 is off the road for 3 months..along with my driving habits (guess why *cough*), Im wanting to make my engine alot more revvy (not so much past 7/8k) buy more from idle - redline speed.
Im already working on Lightweight flywheel + Carbon tailshaft + lightweight rims, and general weight removal throughout the car.
Just want to know engine wise, what can I do to make my engine rev alot faster.
My goal is 220RWKW, with as much reponse, torque etc i can get out of it. Its for the touge, the touge, the touge. So my biggest enemy is turbo lag.
I already have:
(although barely any of this is to do with engine response/revs)
3" Exhaust, Bride bucket seat, Carbon bonnet, coils.
https://www.sau.com.au/forums/topic/143064-i-want-my-skyline-to-rev/
  • Replies 118
Get a super responsive turbo, like the APEXi RX6 B. I have friend here with a S2 GTST with a RB 25 and that turbo, it moved like crazy. what i would suggest is getting your rotating assemly lightend, crank machining, lighter pistons, lightened pulleys, a good damper. get some cams to make the midrange - high end power, get a ECU that can control your VVT, thats about what i can pul out of the hat for you.
reduce the reciprocating mass
so, as you said lightened flywheel, carbon tailshaft
also, im not sure if you can get lightweight pulleys for the rb25, but if you can, get some
are you rebuilding the engine internals?
Want revs huh? Just drop a PFC in it and set the rev limiter to 12,000rpm :laugh: Your engine will love you for it...
Nah seriously,
* Pod
* Turbo Upgrade (hi-flow?)
* Cams
* ECU
* Fuel Setup
I wouldn't be too concerned with the weight reduction stuff... if you're aiming for 220rwkw; you'd be able to piece a setup together that will enable you to pull enough power to move that mass.
if you are serious, which i dont think you are then
strip the boot interior
strip the rear seat interior
change the rear diff gears
heavy duty clutch
powerfc & boost kit & tune
hiflowed turbo
split dump exhaust
fuel pump
cold air intake kit
fmic
suspension complete overhaul (to get the power down)
-shocks, bushes, camber, castor for all 4 corners & pineapples for the rear
good rubber with suitable pressure
The question he is asking is quite a good one.
Notice he said 'not so much past 7/8k but, from idle to redline?
He's not trying to rev the motor to 14,000rpm. The goal is 220rwkw as a peak value.
Cover;
Reducion in rotational mass
Increasing the average power across the desired rpm range,
Reduction in total mass (power to weight)
and finally optimised gearing
is a short answer.
The power goal you have is sensible but, one last thing is getting an optimised response monster's power to the ground. You will need to look at tyres and suspension too.
PM for some more info if you like.
  Gav said:
Keep the clutch pedal depressed - I find the engine is extremely responsive to revving by doing this. :)
lol, i had that happen, it was amazing ;)
Anyhow, on topic, if you read the sticky FI Guide, you'd come along to this thread which covers more than just the topic at hand, but more surrounding issues aswell.
And old thread, but still a very very good one, so read the whole thread
http://www.skylinesaustralia.com/forums/in...?showtopic=9445
:ninja:
If you do decide to go for a rebuild, as well as getting lightened internals you might want to up the compression as well.
You only need low compression for big boost - if you're running low boost then a higher compression won't matter so much, but you'll pick up more power and response. Especially off-boost.
I don't know if it'll make the engine more willing to rev to redline, but it will make the engine pick up in the midrange (which is what you want for touge).
havent yet sky 34, just working towards it.
Rear of boot + rear seats/ rear interior are gone.
rear speakers are gone, passenger door internal pannels are gone,glove box is gone.
So would anything like cams/cam shafts help response?
If i did get a hi-flo, i wouldnt want too much that would increase lag.
ATM im more wanting to work on engine response throughout the rev range.
Gear ratio/diff ratio sounds awesome too.
i think what i want is the engine to rev faster, even if in neutral. i'd like to work on the engine to learn more. love to rev from idle-7/8k in 1 second... mmmmm F1 response.. u know what i mean..
i hope.
thanks for the other suggestions, open to more. will be looking at that thread as suggested.
to blip the throttle in neutral, you need to lighten pulleys, flywheel etc, remove anything draining on the engines spin eg. the A/c and perhaps rebuild with lighter, fully balanced internals. I doubt it would be anything like what you are finding in gt4 though...
if you want to do it in gear, you need everything as above, but more power too. It can only rev as quick as it pulls.
or buy shit rear tyres
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
