Hey guys/girls....there maybe one...
anyway. My ER34 is off the road for 3 months..along with my driving habits (guess why *cough*), Im wanting to make my engine alot more revvy (not so much past 7/8k) buy more from idle - redline speed.
Im already working on Lightweight flywheel + Carbon tailshaft + lightweight rims, and general weight removal throughout the car.
Just want to know engine wise, what can I do to make my engine rev alot faster.
My goal is 220RWKW, with as much reponse, torque etc i can get out of it. Its for the touge, the touge, the touge. So my biggest enemy is turbo lag.
I already have:
(although barely any of this is to do with engine response/revs)
3" Exhaust, Bride bucket seat, Carbon bonnet, coils.
https://www.sau.com.au/forums/topic/143064-i-want-my-skyline-to-rev/
  • Replies 118
Get a super responsive turbo, like the APEXi RX6 B. I have friend here with a S2 GTST with a RB 25 and that turbo, it moved like crazy. what i would suggest is getting your rotating assemly lightend, crank machining, lighter pistons, lightened pulleys, a good damper. get some cams to make the midrange - high end power, get a ECU that can control your VVT, thats about what i can pul out of the hat for you.
reduce the reciprocating mass
so, as you said lightened flywheel, carbon tailshaft
also, im not sure if you can get lightweight pulleys for the rb25, but if you can, get some
are you rebuilding the engine internals?
Want revs huh? Just drop a PFC in it and set the rev limiter to 12,000rpm :laugh: Your engine will love you for it...
Nah seriously,
* Pod
* Turbo Upgrade (hi-flow?)
* Cams
* ECU
* Fuel Setup
I wouldn't be too concerned with the weight reduction stuff... if you're aiming for 220rwkw; you'd be able to piece a setup together that will enable you to pull enough power to move that mass.
if you are serious, which i dont think you are then
strip the boot interior
strip the rear seat interior
change the rear diff gears
heavy duty clutch
powerfc & boost kit & tune
hiflowed turbo
split dump exhaust
fuel pump
cold air intake kit
fmic
suspension complete overhaul (to get the power down)
-shocks, bushes, camber, castor for all 4 corners & pineapples for the rear
good rubber with suitable pressure
The question he is asking is quite a good one.
Notice he said 'not so much past 7/8k but, from idle to redline?
He's not trying to rev the motor to 14,000rpm. The goal is 220rwkw as a peak value.
Cover;
Reducion in rotational mass
Increasing the average power across the desired rpm range,
Reduction in total mass (power to weight)
and finally optimised gearing
is a short answer.
The power goal you have is sensible but, one last thing is getting an optimised response monster's power to the ground. You will need to look at tyres and suspension too.
PM for some more info if you like.
Keep the clutch pedal depressed - I find the engine is extremely responsive to revving by doing this. :)
lol, i had that happen, it was amazing ;)
Anyhow, on topic, if you read the sticky FI Guide, you'd come along to this thread which covers more than just the topic at hand, but more surrounding issues aswell.
And old thread, but still a very very good one, so read the whole thread
http://www.skylinesaustralia.com/forums/in...?showtopic=9445
:ninja:
If you do decide to go for a rebuild, as well as getting lightened internals you might want to up the compression as well.
You only need low compression for big boost - if you're running low boost then a higher compression won't matter so much, but you'll pick up more power and response. Especially off-boost.
I don't know if it'll make the engine more willing to rev to redline, but it will make the engine pick up in the midrange (which is what you want for touge).
havent yet sky 34, just working towards it.
Rear of boot + rear seats/ rear interior are gone.
rear speakers are gone, passenger door internal pannels are gone,glove box is gone.
So would anything like cams/cam shafts help response?
If i did get a hi-flo, i wouldnt want too much that would increase lag.
ATM im more wanting to work on engine response throughout the rev range.
Gear ratio/diff ratio sounds awesome too.
i think what i want is the engine to rev faster, even if in neutral. i'd like to work on the engine to learn more. love to rev from idle-7/8k in 1 second... mmmmm F1 response.. u know what i mean..
i hope.
thanks for the other suggestions, open to more. will be looking at that thread as suggested.
to blip the throttle in neutral, you need to lighten pulleys, flywheel etc, remove anything draining on the engines spin eg. the A/c and perhaps rebuild with lighter, fully balanced internals. I doubt it would be anything like what you are finding in gt4 though...
if you want to do it in gear, you need everything as above, but more power too. It can only rev as quick as it pulls.
or buy shit rear tyres
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
    • But I think you missed mine.. there is also nothing about the 98 spec that supports your claim..  according to the fuel standards, it can be identical to 95, just very slightly higher octane number. But the ulp vs pulp fuel regulations go show 95 (or 98), is not just 91 with some additives. any claim of ‘refined by the better refineries’ or ‘higher quality fuel’ is just hearsay.  I have never seen anything to back up such claims other than ‘my mate used to work for a fuel station’, or ‘drove a fuel delivery truck’, or ‘my mechanic says’.. the actual energy densities do slightly vary between the 3 grades of fuel, but the difference is very minor. That said, I am very happy to be proven wrong if anyone has some hard evidence..
