How much horse power at the wheels is an N1 oil pump good for on an rb26dett?
at what horsepower will it put stress on the pump
thanks
ALSO: does anybody know where I can get a tomei oversized oil pump from for a good price. (for rb26)
I am willing to order from japan etc
thanks heaps.
https://www.sau.com.au/forums/topic/143067-n1-oil-pump-question/
thanks
thanks heaps.
i just bought a tomei pump for $1574 at the start of this month but have to wait till end of the month to get it, i have a n1 pump you can buy only 5000kms on it, pm if your interested
Well i run a N1 pump and i push 450awkw. form what i have read on the forums is that the N1 has a brittle drive gear that breakes if you hit the revlimiter to often. I am currently scratching my head if i need to buy a JUN or a Tomei pump, because my engine has cost me quite a few $ and dont want to go through the entire process again after only 5 months.
450. wow thats alright then
i was told that 300kw at the wheels is pushing the N1 pumps.
I have been told I should use a tomei.. but yes, they are rather expensive.
Im looking at about 450awkw when its done
What other options are there?
JUN, Tomei... others?
are they all a similar price? and are there any to stay away from
thanks again
it really depends on how the car is driven.
N1 pumps tend to fail quite a bit on high rev drag cars, because of their rev limiter style, and the way they are launched....
at the same time though Jun or Tomei oversize pumps are a lot better, but it comes with a price.
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
