Hey guys i was just wondering if anyone had any idea how to disable the ATESSA system to lock it to RWD. I've heard rumours its as simple as removing a fuse but i can't find the information i need to guide me. I only what this to be temprorary as i've become fond of the AWD system but what a chance to drive it as a RWD car before i change my tyres lol
any help would be greatly appreciated, as would links to any similar threads.
cheers
https://www.sau.com.au/forums/topic/143070-atessa/
R32 just yank the fuse, R33/R34/Stagea is different and there are different ways which some will tell you wont cause damage and some will tell you will, but sure fire way is to just remove the front drive shaft, and put back in when you want awd goodness :laugh:
https://www.sau.com.au/forums/topic/143070-atessa/#findComment-2665895
Its under the dash....does 4wd and ABS, so its not fun doing high speed braking with it pulled out....
just run a switch to flick it on and off, makes it easy, but be careful doing so, usually ya gotta turn off the car to change between 4wd and 2wd or aparently you can do damage to the atessa...or atleast flick it on idle
Jez
https://www.sau.com.au/forums/topic/143070-atessa/#findComment-2666314
theres a fuse under my bonnet saying "ptc heater/4wd"
Thats the one! yank it out - instand 2wd. Have done this many times (i own a r32 yes) doesnt hurt anything all is good. Makes it easy if you have access to only a 2wd dyno which i why i pulled it out.
Have fun! :D
https://www.sau.com.au/forums/topic/143070-atessa/#findComment-2668101
  • 6 months later...
The fuse under the bonnet is for the attessa motor, pulling it shouldn't kill abs. (doesn't appear to on mine anyways)
The fuse under the dash is for the control unit, this kills abs cos it is also the abs module.
7yphon:
dirtgarage has a group buy running for an easy to install harness to do just that.. in the group buy section. If you have to ask how, it might be better that you go that way.
https://www.sau.com.au/forums/topic/143070-atessa/#findComment-3163835
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
