Hey guys i was just wondering if anyone had any idea how to disable the ATESSA system to lock it to RWD. I've heard rumours its as simple as removing a fuse but i can't find the information i need to guide me. I only what this to be temprorary as i've become fond of the AWD system but what a chance to drive it as a RWD car before i change my tyres lol
any help would be greatly appreciated, as would links to any similar threads.
cheers
https://www.sau.com.au/forums/topic/143070-atessa/
R32 just yank the fuse, R33/R34/Stagea is different and there are different ways which some will tell you wont cause damage and some will tell you will, but sure fire way is to just remove the front drive shaft, and put back in when you want awd goodness :laugh:
https://www.sau.com.au/forums/topic/143070-atessa/#findComment-2665895
Its under the dash....does 4wd and ABS, so its not fun doing high speed braking with it pulled out....
just run a switch to flick it on and off, makes it easy, but be careful doing so, usually ya gotta turn off the car to change between 4wd and 2wd or aparently you can do damage to the atessa...or atleast flick it on idle
Jez
https://www.sau.com.au/forums/topic/143070-atessa/#findComment-2666314
theres a fuse under my bonnet saying "ptc heater/4wd"
Thats the one! yank it out - instand 2wd. Have done this many times (i own a r32 yes) doesnt hurt anything all is good. Makes it easy if you have access to only a 2wd dyno which i why i pulled it out.
Have fun! :D
https://www.sau.com.au/forums/topic/143070-atessa/#findComment-2668101
  • 6 months later...
The fuse under the bonnet is for the attessa motor, pulling it shouldn't kill abs. (doesn't appear to on mine anyways)
The fuse under the dash is for the control unit, this kills abs cos it is also the abs module.
7yphon:
dirtgarage has a group buy running for an easy to install harness to do just that.. in the group buy section. If you have to ask how, it might be better that you go that way.
https://www.sau.com.au/forums/topic/143070-atessa/#findComment-3163835
    • Thanks for the explanation, I'll sleep a little smarter tonight! Cheers.
    • Being this happened about 4 years ago, i honestly forget exactly what is was, but I wound bringing to Simon at SR Werks when he was here in NY. He was able to properly diagnose and repair. I believe it had to do with the harness behind my dash.
    • It's because the air comes in over #3 & #4. The two "dead" ends of the plenum are at #6 & #1, with #6 being a little more "compromised" (Sorry about all the quote marks) than #1, due to the shape. So you get the dead end effect at #6 & #1 where dynamic pressure converts to static pressure, likely causing the air flow to be highest for these. The others are then just working in from the ends to the centre. 6 -> 1 is only valid for FFPs.
    • Cut back on the attitude champ, no one is obligated to help you. The chances of Forester owners on here are quite low, considering this forum is called Skylines Australia. https://www.subarupartsdeal.com/parts/subaru-under-cover-front~56410sa000.html ^ that picture looks wrong, because if you see the diagram, 56410SA070 looks correct. You can always check where the mounting holes are on your car, and compare them to the pictures.
    • Hey Duncan, I've always set them up from 6 -> 1. Due to slightly higher EGT's, I also add a small amount of fuel to cylinder 6 & 5. I understand why you start at 6 but curious as to why you then continue somewhat based on firing order? Thanks
