Hey guys
Please help, yes ive read every page that has somthing to do with 02 sensors on this site.
This is my situation
On my Cefiro, i pulled off the dump heat shield and left it off. This caused the WIRE AND PLUG for the 02 sensor to be melted to pieces. The whole loom was roasted as well, leaving only about 10 cm of loom near the chassis.
I have ordered a new 02 sensor alredy picking it up this afternoon and ive got a 3 pin connector as well.
Now my problem is.
What sort of wire can I use to extend the 3 wire loom, what is the sort of Heat proof coating I put over it and also lastly
HOW THE HELL CAN I REMOVE THE 02 SENSOR? I can get a Open ended 22 over it, I can get plenty of leverage, AND ive even Soaked it in Rost Off (angriest version of WD40/Penetrene) and used all my strength but the thing wont budge.
Am I just weak or is there another way - I cant get hold of a 02 socket (Repco/autobarn/supercheap) dont have one - so any other suggestions?
Hope you guys can help
Regards
Kim
https://www.sau.com.au/forums/topic/143077-urgent-help/
most exaust shops will have a nut that you can weld onto ya manifold for ya 02 sensor . try heating ta old one up with a oxy if ya have one or try putting a pipe on ya spanner for more leavearge
https://www.sau.com.au/forums/topic/143077-urgent-help/#findComment-2666033
it's not easy getting off.. you can run the car without the o2 sensor for a while if you need to. Maybe try undoing it when the dump is warm. Obviously not fuse-the-fingers hot, but once it's started to cool down to touchable levels.
just zip-tie the o2 plug to the firewall, will stop it flopping down and melting in the future. That seems to have worked for me. If you want to insulate it (say if you run at regular full boost levels), I'd use some of the stuff you use to insulate turbo lines.
https://www.sau.com.au/forums/topic/143077-urgent-help/#findComment-2666519
Maybe have to take the dump off to get enough leverage? that's what I had to do with my original dump pipe to get it off as a last resort.
where would you buy insulative stuff, gordo?
will places like supercheap have that?
Try Revolution racegear, there is one in moorooka in bris..
http://www.revolutionracegear.com.au/?fa=R...6332E944FB94049
Either that or a specialist hose shop may have it to insulate fuel lines, etc.
https://www.sau.com.au/forums/topic/143077-urgent-help/#findComment-2667268
Had the same problem before... surely it was a biatch to take off. O2 sensor wrench was way too expensive ($45 for a socket... forget it).
So, went to Bunnings to the plumbing section, got some sort of wrench for plumbing / piping, octangular in shape, fits perfectly. Used a long stainless steel rod along the wrench for leverage, and half a can of WD40 later... hurrah!
I hope that helps..
DD
https://www.sau.com.au/forums/topic/143077-urgent-help/#findComment-2667805
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
